![]() | Home > Group Buys > Genuine Landrover TD5 Rev Counter |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Something looks like it went wrong with PayPal but your order and payment have come through fine ![]() ![]() ![]() |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
Hi Martin, that's spot on, but correct me if I'm wrong, but 30cm of wire supplied isn't enough to go to the back of the rev counter from the ecu? Cheers |
Correct - it's not a full fitting kit (you would also need power and illumination and ground for the rev counter).
It's simply to give a connection to the rev counter signal on the ECU plug. I could put together a full retrofit wiring kit but it would be more than �1.60 ![]() ![]() ![]() |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
Just caught up with this. I'll give Dan a call on Monday
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
Hi Martin, do you know if its possible to take the power, illumination and ground from the clock assuming I don't plan on reusing it? |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
rev counter received - many thanks Dan
![]() ![]() I have seen full wiring kits for td5 rev counters from Croytec for �20 if that helps anyone? cheers |
You can take ground and illumination from the clock. The power for the clock is permanent so you need to borrow an ignition switched source from another gauge. ![]() ![]() |
Croytec's "loom" appears to be 5 spade connectors on a short piece of wire each. Not a plug-and-play loom?
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Is there a 'rule of thumb' as to which vehicles will have the rev counter wiring in place behind the instrument panel and which will not? 2005 Td5 | 90 Station Wagon | Tonga Green
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Check pin 19 on your black ecu plug if has a grey wire then 👍 Just gotta find it behind the clocks 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Pin 19 is connected for vehicles with ABS so not always an indication it will be behind the clocks.
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 ![]() ![]() ![]() |
Well it's ticked over the end date of 31 Jan , but within a Land Rover margin of timing
![]() (Good excuse, was in Grampians, VIC) I'm in if this is still happening. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
Read earlier in the post as Dan has posted details for purchase 👍 2008 110 2.4 XS Utility (Hagrid)
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 81 ![]() ![]() ![]() |
Bit late to this one but hopefully it is still open.
Any problems Dan just let me know. Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
