![]() | Home > Td5 > Miles from fresh tank? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
Around 300
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Routinely get 600kms per tank with low light just coming on. Mainly 7 Kms twice per day to work.
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Thanks interesting I know the 90 and 110 have different sized tanks however following filling up my 90 to the brim the light comes on after 260 miles…I have checked for leaks and nothing visible. Have also unplugged the MAF so was thinking maybe egr or injector seals?
Injector seals, I wouldn't jump to that unless you are getting derv in the oil.
I always found an oil and filter change (including Fuel) made a difference to MPG. But best to look at stuff that is affecting the engine. Belt tensioners wear, or alternator could be working hard, drag from anything on the engine. Brakes dragging from the calliper pins worn. Rubbish fuel doesn't help either. Then MAF, MAP sensors could do with a clean (electrical cleaner to remove oil etc). Intercooler Flush/Clean. ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
I get around 300 to a full tank. (110) 1999 Defender TD5 110
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
340 to 360
26-28mpg 110 |
Used to get 340 every tank but it seems to have dropped to around 310 since the weather got cold
![]() My build thread http://www.defender2.net/forum/topic17615.html |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Mmm, I was getting 380+ to a tank.
I'm getting roughly the same with my 2.4 Puma. Cheers Andy |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
I would get 280ish if I drove like my dad. In a 90
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Me.......240ish
The wife 280 ish Caterham 2800 ish Worth mentioning the 2.2 is the same, sometimes worse !!!! |
This is full to light also so should be another 20-40 miles to empty |
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 ![]() |
![]() I'd tentatively suggest that you're not driving it properly if you get that mileage from a tankful..... ![]() ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
About 380 from my 90 maybe 400 at a push 2002 90 Td5 Station Wagon
