![]() | Home > Maintenance & Modifications > Rear electric windows |
Wire them up like on the disco 1 and 2, they had a switch to stop the rear passengers from using them. Ray
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17706 ![]() ![]() ![]() |
Give the kids boxing gloves and lace them on!
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Nice idea blackwolf but with 2 boys of 4 and 2 who are already smacking each other I only think boxing gloves might escalate things
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Is it so far plug / bolt and play?
Does it require any drilling etc? I contacted Andy and he said its in one of the magazine soon so will probably see more of them. Looks like another thing to add to the list. I quite like where the buttons are on the back of the cubby as I can reach them as well as the kids. OUrs are 6 and 9 so are generally better at being told what to do ![]() Kit comes with this lot Contents of kit. it would be composed by 2 window Regulators with motors 2 switches 1 switch holder 1 full electrical harness included relays and safety breaker screws and fixing stuff. Kind regards Andy Limbert Managing Director www.vcdparts.co.uk |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1866 ![]() ![]() ![]() |
I was in touch with Andy at VCD also about these, but the finer details, like how the wiring loom is routed etc is all very vague and sounds a little like he's not actually fitted the product himself/had it fitted.
Romadog, be interested to hear/see how you get on with this. Its on my list of wanted mods, but personally I'd prefer a more OEM looking switch than the one supplied with the kit. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Yes plug n play - as I like it. No need to fabricate/bodge anything !
As shown above one of the mounting holes used, previously had a clip for CL loom. If you wanted you could drill another hole for the clip, but as the clip was so tight to the loom I was unable to slide it down - don't want to damage the wiring and create issues in the future. However the loom is still well supported. to close the windows I needed 12v power so used jump leads from battery and some short lengths of wire from the jump leads to the terminals in the motor plug. this either raised or lowered the mechanism, allowing mee to position for easiest access to bolts for connecting to window tabs. Small spacers are supplied to go between the tabs and mechanism. Dropped twice but they didn't roll far ! The bolt on the left is a LR original from holding the manual winder and the one on the right was supplied for mounting the mechanism. As they are the same I just re-used what came to hand. The original cross head screws for the tabs were not used as they are harder to remove, requiring pressure which could bring a James May " oh c ![]() ![]() Click image to enlarge He hasn't the info yet as mentioned earlier, full fitting info is on its way ![]() The routing will be pretty self explanatory. I have laid it out to see what goes where etc. Relay and fuse would be mounted in battery box and wiring routed from there via grommets already fitted to your cubby box. I thought about matching switches with the front but this would require a much larger and deeper switch box that people would say was too big so you can't win. Also, do you want the switches on the door card instead or on dash for easier driver access. As my doorcards are going to be custom built due to issue I had early on with proximity of my Bpost hoop for roll cage this may be an option for me - however matching switches will be too long for where they are best operated by a strapped in passenger. Last edited by Romadog on 21st Dec 2016 5:16pm. Edited 1 time in total |
Neat
Have you a close picture of the switches? Could they be changed for OEM ones (not that I'm over bothered as long as they work) Thanks |
Taking dogs for a walk for a break back shortly !!
I knew I should have taken a close up photo of the switches !!
They had six contacts on them I will compare with some RR classic ones, though the ones supplied look perfectly capable. It took longer to get the old manual winders out than it took to fit the new electric ones !! I nearly went for the Hofele system when it was available but glad I didn't now. |
More info....
The switches supplied ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 6 connections - the RR Classic switches have 5. However for me as I have an auto console, I'd prefer not to drill or cut this .....yet ! I think that adding switches to my Td5 dash would be preferable as then I can reach easily. No use for this area of dash and if a passenger in the rear wants their window down they can ask ! I acquired this switch in photo below a long time ago. It has 6 connections for each side. Does anyone recognise what vehicle it would have come from?? Can't remember myself ! ![]() ![]() Click image to enlarge Anyway back to what was supplied The loom supplied consists of pre-wired switch plugs with a pair of wires from each to go to the door. ![]() Click image to enlarge ![]() Click image to enlarge Plugs for these wires to connect to female plug on electric motor ![]() Click image to enlarge Also these wires are positive and negative connections for switches. These connect to Relay which looks to be fitted in battery box. ![]() Click image to enlarge ![]() Click image to enlarge From relay is a blue wire that is in conduit, which will be the ignition live feed which would go to the fuse box ![]() Click image to enlarge Stick on blanking plates supplied. Also a bag of small zip ties. ![]() Click image to enlarge Will re look at what way I wire them after Christmas ! |
Looks like quite a good kit with everything included.
Switches look ok, I think Defender ones have 6 pins so could swap? I like the location in a pod behind the rear cubby box, that way they rear passengers can reach them and I can also, Does it come with this pod? Keep me updated on how plug and play it is... Thanks ![]() |
Yes switch pod is part of kit.
It is as plug and play as you can get when Land Rover didn't offer rear electric windows. |
Just ordered my kit from Andy Limbert, should arrive tomorrow.
At long last the bungee cords which stop my rear windows from opening themselves may soon become a thing of the past! ![]() |
Well mine are now shut until I get wiring and switches fitted to open them again !!
