![]() | Home > Technical > LT230 transfer box refurbishment. - bush left over on the be |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 ![]() ![]() ![]() |
It could be a locating dowel. Parts 2, 25 or 26.
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 ![]() ![]() ![]() |
Looks like 25 as its missing in the top picture NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Thank you. Will check. Think you are right. Luckily not within the transfer box!
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
If it's not for there compare the size against the intermidiate shaft.
Some housings flog out where the "0" rings sit, there is modification where a bush/sleave is inserted. This requires the casing to be drilled/machined and the bush pressed in Cheers, Kyle. |
It was the bush Kyle segmented! 😏
