![]() | Home > Technical > Sycro gearboxes slick shift |
Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142 ![]() ![]() ![]() |
Bought one of these from the stoneleigh show:
http://www.onlinegearboxparts.com/product/...lickshift/ Did um and ah over buying one for 75 quid with not knowing the real difference it would make, finally got around to fit it yesterday, took about 20 mins to fit and I'm so glad I did, the gear change is so much better, closer together and feels tighter, big thumbs up 👍 |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5276 ![]() ![]() |
I am toying with the idea of fitting one of these, to make gear changes easier, sometimes I struggle with second gear and sometimes 3rd gear.
alpacaman Member Since: 07 Mar 2016 Location: Gloucestershire Posts: 160 ![]() ![]() |
It certainly makes gear changes shorter and sharper. Whether or not it will make them easier if you already have an underlying problem is not something I can comment on.
I think its me getting used to a landy Gear box, I am used to a 306 gear box.
I know landys do not like been rushed up the box, so I must learn not to drive like I am in the 306. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
Landy s are very much like ladies then Procta.....In that they don't like to be rushed up the box
![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
![]() ![]() ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2692 ![]() ![]() |
I can honestly say, that the throw on the gearstick in my 110 isn't such that I feel the need to go and spend money on an item that speeds up the gear change when if you have an issue you should slow the gear change down. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
Just to change the topic slightly, but i was wondering if anyone has had one of there gearboxes and are they any good ? Clayton.
