Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4787 |
Thought I might pop some pictures up of my defender. In no particular order, just it and some of the things I have done to it, for all to see
This is how it looked back in 2008 when I was 16. The only upgrade being the alloy wheels For comparison this was a few weeks ago Click image to enlarge Although it is lowered and on road tyres suspension etc I still like to use it the way landrover intended. It just means I have to clean it quite often! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge That better! Interior wise it is xs spec without air-conditioning (for now ) with alcantara headlining. I have fitted range rover classic illuminated stalks and a mini Cooper steering wheel Click image to enlarge Also every single lamp is led. A cool shot my cousin took whilst playing around at home Click image to enlarge That's all I have for now. Any questions or comments most welcome 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 7th Oct 2019 6:37pm. Edited 3 times in total |
26th Nov 2016 5:31pm |
Lowered AND off road
That'll confuse the haters Kudos to you, nice colour co-ordination too. |
26th Nov 2016 5:41pm |
Thank you GREENI
The photos of the deep water were at LRO 2016 off road course, I must say I got some raised eyebrows! Although it is lowered with careful route planning and sensible application of power it will go most places a standard one would. I'm really impressed with the Hankook tyres - the off road grip isn't far off an all terrain! I think the Ashcroft LSD centre diff helps out too 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Nov 2016 6:04pm |
Another one from the LRO 2016 course
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Nov 2016 6:15pm |
Final one for this evening quick wax but no tyre dressing
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 26th Nov 2016 6:20pm. Edited 1 time in total |
26th Nov 2016 6:20pm |
Hi Stiff1
The stalks are quite easy, all the wiring colours are the same and the slider on the wiper stalk varies the intermittent wiper delay as per the Range Rover. They came off my donor Range Rover Classic. I had to remove the hazard part of the switch and make up a bracket to clamp the switches to the steering column. Then make a bracket to hold the main headlight switch. I did it in an afternoon. I think I took some pictures of the process. I'll try and dig them out The mini Cooper wheel is a direct bolt on and works the canceling ring for the classic stalks nicely! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Nov 2016 6:27pm |
It's 36 spline isn't it?
26th Nov 2016 6:32pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
That would be great if you could, really interested in this and never heard of it being done before.
26th Nov 2016 7:10pm |
I'm not sure to be honest I have never counted them. My mate had it lying around in his garage and I thought I'd give it a go and it fitted! The good thing is that it is smaller but not too far away from the stalks. 2002 90 Td5 Station Wagon
26th Nov 2016 8:30pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Nice looking landy you got there and using it of road as well 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
26th Nov 2016 10:18pm |
Cheers L110CDL
Because they are so good off road as standard lowering them and fitting anti roll bars still leaves them pretty good. It does everything I want and its great on road too, the best of both worlds in my humble opinion Plus you don't have to rub them up trees and stuff to have fun off road so it stays looking nice when it is doing Chelsea tractor duties 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
27th Nov 2016 2:54pm |
Darcy Fairfax Member Since: 05 Oct 2014 Location: London Posts: 721 |
Love your truck
27th Nov 2016 3:10pm |
Thank you Darcy Fairfax 2002 90 Td5 Station Wagon
27th Nov 2016 3:16pm |
L90DNY Member Since: 09 Feb 2016 Location: Somerset Posts: 117 |
Looks great. Have you made any performance mods?
27th Nov 2016 3:31pm |
