Home > Maintenance & Modifications > How to remove the plastic side vent |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4210 |
I removed mine at the weekend, it just pulled out, but it did leave a couple of it's little locating lugs behind. 2007 110 TDCi Station Wagon XS
19th Oct 2016 7:35pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3751 |
Pulls out from the front?
Can the 'lugs' be put back in when re fitting the new one? Thanks |
19th Oct 2016 7:40pm |
Click image to enlarge |
19th Oct 2016 7:44pm |
Just prized it out from the outside with a plastic spatula so as not to damage surrounding paint . As above, it was those little lugs that remained in the car. 2007 110 TDCi Station Wagon XS
19th Oct 2016 7:47pm |
Thanks all
19th Oct 2016 8:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
They re prone to breaking as suggested already.
I'd keep well away from paint, use some stiffish wire and thread through and back out again in a 'U' shape. If required use multiple pieces through the grille. It'll then act as a puller and you can evenly distribute the force better, but even then the devils do break on the pins. LR I believe use a tool like a flat bladed screwdriver but the tip bent 45degrees and use that as a puller instead. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
19th Oct 2016 8:52pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
You mean like a trim removal tool? You can buy a set of those for little money.
20th Oct 2016 10:56am |
^ I have them somewhere
Bought from China with all sorts of plastic little tools Now I have a use for them Will search them out... |
20th Oct 2016 11:11am |
Since I own the Defender my attitude to clearing up the house/attic/garage etc. changed from "nah, I'll never need this thing again -> throw away" to "nah, I'll never need this thing again -> store in a very safe place" |
20th Oct 2016 11:23am |
Found them
Click image to enlarge so tomorrow nights job...remove and fit |
20th Oct 2016 7:08pm |
