Home > Maintenance & Modifications > How to remove the plastic side vent
Stacey007
Hello
I have this shinny metal vent for my truck off a forum member who did not require it Very Happy
How does the original vent come off? from the inner wing and push out? there does not seem to be any screws on the outside like the new one?
Thanks
the new one is similar to this
Post #572116 19th Oct 2016 7:31pm
Bluest
I removed mine at the weekend, it just pulled out, but it did leave a couple of it's little locating lugs behind. 2007 110 TDCi Station Wagon XS
Post #572117 19th Oct 2016 7:35pm
Stacey007
Pulls out from the front?
Can the 'lugs' be put back in when re fitting the new one?
Thanks
Post #572120 19th Oct 2016 7:40pm
dorsetsmith
Post #572123 19th Oct 2016 7:44pm
Bluest
Just prized it out from the outside with a plastic spatula so as not to damage surrounding paint . As above, it was those little lugs that remained in the car. 2007 110 TDCi Station Wagon XS
Post #572126 19th Oct 2016 7:47pm
Stacey007
Thanks all
Smile
Post #572140 19th Oct 2016 8:18pm
They re prone to breaking as suggested already.
I'd keep well away from paint, use some stiffish wire and thread through and back out again in a 'U' shape.
If required use multiple pieces through the grille.
It'll then act as a puller and you can evenly distribute the force better, but even then the devils do break on the pins.
LR I believe use a tool like a flat bladed screwdriver but the tip bent 45degrees and use that as a puller instead. $W33T $0U7H3RN $UG4R
Post #572161 19th Oct 2016 8:52pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
You mean like a trim removal tool? You can buy a set of those for little money.
Post #572259 20th Oct 2016 10:56am
Stacey007
^ I have them somewhere
Bought from China with all sorts of plastic little tools Smile
Now I have a use for them Laughing
Will search them out...
Post #572262 20th Oct 2016 11:11am
macfrank
Very Happy
Since I own the Defender my attitude to clearing up the house/attic/garage etc. changed from "nah, I'll never need this thing again -> throw away" to "nah, I'll never need this thing again -> store in a very safe place" Wink
Post #572263 20th Oct 2016 11:23am
Stacey007
Found them Smile
so tomorrow nights job...remove and fit
Post #572355 20th Oct 2016 7:08pm
