Home > Puma (Tdci) > Clutch!!!!! |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 |
What is the part number or the reference number of the clutch that won't fail every 25.000 km!?!?!?!?!?!?!?!
I'm very disapointed, it will be the second clutch!!!! the first time, it just make noise, then we changed, now it make a Defender stops!!! it's ridiculous, with a car that runs 80% of time in good tarmac!!! The question is, the latest clutch models had this disc spring problems solved? Because if not, I prefer to change to a 200 or 300 glorious Tdi!!! Sorry about the outflow!!!! If someone could help, I will be gratefull!!! I will just call for LR assistence, but if the car was a unit of an army around the world and was in the middle of battle field and the clutch failed????? With a Toyota it will never happen!!! |
4th Feb 2011 11:07pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4655 |
Hope not-the wife drives mine! 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
4th Feb 2011 11:51pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
I'm on my third clutch in 20000 km, this one seems ok so far.
Allan Last edited by Allan on 5th Feb 2011 12:15am. Edited 1 time in total |
5th Feb 2011 12:14am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Hows your clutch ? and how long has it been in ? there are some guys still on there first NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
5th Feb 2011 12:16am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
When I took one out for a spin I changed into second but it wasn't having it, so back into first to get the revs right up then into second. With my Series and TD5 you didn't need to get the speed right up for it to pull away in second. The turbo comes in quite late at 2600 rpm (my SAAB comes in at roughly 1600 rpm), I wonder if it is driving style although I doubt it and it shouldn't matter anyway - clutches just should not be going!
Going back to the OP question, I also wonder if they have developed a better clutch? |
5th Feb 2011 7:37am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Turbo at 2600rpm there's something wrong there then, don't compare all Pumas to your one quick spin. Original Member Pie n Pea Club.
110 HCPU Tipper |
5th Feb 2011 7:45am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Second clutch? I´m on my third! Is you r engine running smooth or somehow rough? Since a long time there is a 2nd type but there are some landies that keep failing. Puma 110" SW ............................................................. Earth first. Other planets later |
5th Feb 2011 9:11am |
The clutch was replaced under warranty about early 2010, owing to the cluch springs rattling when the engine was turned off. Have had no bother since and it is a joy to drive. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
5th Feb 2011 11:35am |
Same as i'm on my third and now all is well NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
5th Feb 2011 12:14pm |
Oops yes it comes in less than 2200rpm at some point, mis read it |
5th Feb 2011 1:46pm |
Ok!!
But for each you that had your clutches failed, how occur by a way that makes the vehicle impossible of keep going? And, how much miles or kilometers those who imagine that the latest clutch is doing well already done with this clutch? And, Land Rover did or didn't a clutch modification? Is another reference number for the clutch that don't fail? What is the diference betwen the good and bad clutches? About the engine, Is it could be damanging clutches because of it's running rough? How? And how to solve? (It's software already been upgraded in a service buletin, and I prefered the old version!, but...) I note some rough but not sure about it! thanks for the repplyes!! regards!! |
5th Feb 2011 2:43pm |
So far there is just one "upgrade". Roughness as a cause is just a theory. The friction plate has a central damper with small coils to absorb "some roughness at idle and making the gearbox input shaft quiet. Probably at some point those coils get knackered. Overall the friction plate has a progressive mechanism where 2 big tight spring coils are stressed and then a second pair (loosen ones) follow at greater stress. Probably in your case the central hub is absolutely gone. If you have not mod anything then I would ask for a proper engine tune at your dealer.
Search about this topic and you`ll see a picture of my clutch with some explanations. Keep us posted. MK Puma 110" SW ............................................................. Earth first. Other planets later |
5th Feb 2011 2:59pm |
caminos_de_ibiza Member Since: 23 Mar 2011 Location: Ibiza Posts: 9 |
Hi, I dont kow the part nr. But.
on my defedner 2009 110sw the clutch burned trough at 38K km. I got the car with 9k from the dealer. use it at wotk for towing etc. and some offroad, The local landrover dealer here in spain did chane the clutch under warranty. I paid 1000 euros for a nrw one. I think it was ridicilus. the dealer argued that it was my driving. I drove many landys already, this is the first clutch i burn. i find it very stange... Can anyone tell me about the land rover warranty in this case. thanks 2009 Defender 110 SW |
23rd Mar 2011 11:13pm |
creo que el dealer te esta viendo los h.....s. Lo más probable es que el emgrague haya estado jodido de fabrica. Puma 110" SW
23rd Mar 2011 11:51pm |
