Home > Puma (Tdci) > Clutch!!!!! |
caminos_de_ibiza Member Since: 23 Mar 2011 Location: Ibiza Posts: 9 |
Click image to enlarge Click image to enlarge Click image to enlarge here are some more pix of the burned clutch. didnt talk to a 2nd mechanic yet. thanks for your help guy. !!!! 2009 Defender 110 SW |
28th Mar 2011 9:44pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
I can npot tell if the plastic (teflon) is white or dark grey (updated part).
Are the coil springs loose? atte MK Puma 110" SW ............................................................. Earth first. Other planets later |
29th Mar 2011 12:03am |
hi,
the teflon is dark grey. I had a mecanic look at it and he said it most likely broke due to material failure. pretty much sure it was a bad clutch from stock. especially after i explained him how it happend gradually that the clutch went. He asked me if I maybe slipped the cluth in some occacion until I could smell it, Like offroading or similar. I do drive my care offroad in the hills of ibiza, but know how to aswell. never had any clutch penetratings smell, neighter when it went off and I basically rolled home and knew it was the clutch. to be honest it doesnt drive so good know with the new one. I drove like 400 km and im thinking to get it checked out by my mecanic to know it for sure. cheers..... 2009 Defender 110 SW |
31st Mar 2011 7:01pm |
If it is grey, then it is the old version. DO a search and you will find a pic showing the two types. I believe you can claim it under warranty then. Puma 110" SW
31st Mar 2011 9:04pm |
