Home > My Defender > Oakseywicks Bonetti 110 XS & Java black 90 special vehic |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 |
Clayton.
24th Sep 2016 7:26pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2048 |
What make are your side steps on your 90 ?
24th Sep 2016 7:54pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3792 |
Hello
What are you plans for the sankey Great stuff... |
24th Sep 2016 7:56pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
I believe the side step are Land Rover ones they were the same as the previous on the 90 but in stainless steel, I have seen some advertised new before but they were around £600. I got mine off eBay for a lot less second hand. |
24th Sep 2016 8:24pm |
Thanks. No part numbers on them then?
24th Sep 2016 8:28pm |
Hi Stacey not 100% sure yet, I will refurb and repaint it, black chassis and properly do the tub the same as the 110 bonetti grey. I want to make some sort of lid to make it water prof and mount a bike rack on top. Also put alloy wheels on etc. I will post a thread when I start. I have been watching your sankey build looks good. |
24th Sep 2016 8:31pm |
Hi Daz there the same as the ones in link below but in stainless hope this helps. http://www.ebay.co.uk/itm/Land-Rover-Defen...Sw4shX4p0k |
24th Sep 2016 8:38pm |
Thanks for the link.
24th Sep 2016 9:02pm |
So yesterday for the first time this year I got some time to spend tinkering checked all the fluids etc and got round to fixing the washer jet on the 110 after in fell off over Christmas.
Click image to enlarge Initially I had thought it was a dash out job to replace the jet but after a quick search on here found out you could just replace the jet. Lucky I had a spare kicking about so set about separating the jet from the spindle. This took some time and plenty of but found that leaving it soaking in a bowl of hot water made leave ring the 2 parts apart easier so using a flat head screwdriver, bench vice and some good old brute strength it looked like this. Click image to enlarge I made sure that I glued it on this time so the ice would not force it off again took some force to push it on the shaft over the ridge to stop it coming off but all done should now be ready for the MOT this week. Click image to enlarge Just a few gratuitous shots Click image to enlarge Click image to enlarge Click image to enlarge |
29th Jan 2017 9:53am |
Very nice Clayton.
29th Jan 2017 9:29pm |
So today I actually got a day to spend doing some jobs on the 110, firstly decided to check and clean all the places where mud gets stuck on the chassis and could not believe the amount of crap under there half filled a bucket
Click image to enlarge Should help reduced corrosion of the chassis. Next changed lights to clear leds Before Click image to enlarge Click image to enlarge After Click image to enlarge Click image to enlarge Also fitted some gloss black mirror covers. And what of the 90 well it has turned into a very expensive trellis for the clematis in the drive as the clutch has gone and it's been parked up for 10weeks while I decided on which clutch and saved the funds but have now ordered a clutchfix HD1 clutch and new valeo dmf and will be going in to be fitted in the next two weeks Click image to enlarge Click image to enlarge |
15th Jul 2017 7:59pm |
Nice delivery today wallet is a bit lighter though
Click image to enlarge Click image to enlarge Hopefully off next to the garage to be fitted Got to say fast delivery from TMD Tuning |
19th Jul 2017 6:57pm |
Getting ready for the maiden trip with the sankey, new cover fitted until I decide how I want to build my camping trailer and new number plate fitted with a little homage to the forum
Click image to enlarge Click image to enlarge Off to exmoor tomorrow for the week so if anyone sees us give us a wave as my little boys love it. |
28th Jul 2017 6:49pm |
Nice number plate will keep a look out for you if you are visiting Braunton area or on my travels have a good one Clayton.
29th Jul 2017 9:51pm |
