![]() | Home > Maintenance & Modifications > Bloomslang loom is it needed with Crystal headlights & B |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
Couldn't read this. What does it mean?...Does it mean that Defenders subsequent to the mentioned Vins have been upgraded etc so no longer have a switch issue? Pickles. |
Interesting, but when reading this, it is clear that the Landreiziger loom is a much simpler and better piece of engineering design than the Land Rover solution. Landreiziger all connects simply under the bonnet, while with Land Rover you have to dismantle steering wheel, half the steering column surrounds, split wires, feed them from cabin to engine compartment, etc. They even make you take out the coins tray. ![]() But of course, Land Rover engineers in all their wisdom will have it right here, Landreiziger must have missed some important things in their simple design. I guess I have to start worrying now about what my Dutch solution can do bad to my truck. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
All the jist really is, is A, keep it simple, B, take current direct from battery for less voltage drop, C, reduce current through switch to mA's instead of nearly 10A.
Quite why this wasn't does as standard I don't know... Relay switching is basic but to directly switch current is a very outdated solution, abd nearly 10A is fairly high. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
... that's very in line then with the Defender, isn't it? ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
True, but the design isn't particularly faulty.
Then again, could that be contested?.. ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
There wouldn't be any problem with the stock switch and wiring if the switch was beefy enough and the cables were of sufficient grade.
Effectively all a relay is is a remote control switch. |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
Fitted the Boomslang loom (from Paddock) this evening. Put the earth to the front wing bolts and ran the live along the chassis to the battery box.
Took about 40 mins altogether and my only issue is that I've needed to run the conduit across the top of the fan cowl as I couldn't get it fed through underneath in the time I had available. I suspect when I decide what I am doing with the headlights and have it open again I will try to find a better route to the drivers side lamp. Not sure if its wishful thinking but even with the standard bulbs and lenses it seems brighter. Keith |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3796 ![]() ![]() |
^ sounds good
I can't remember where I routed my spots permanent live, I know it was in convoluted tube but I think it was the inner wing.
Quite a bit of theadong involved then unde and in. Definitely needs to be fused near the battery and not at the front otherwise you've got an unprotected cable run. With earths on each side where have the rest of you earthed too? Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
I connected the permanent live of the kit directly to the alternator B+. Easier than routing to the battery box (at least on my 300Tdi - I know it's bit awkward on the Puma).
The kit has an inline fuse at the end where the live termination is made, for me (with the most direct threaded route) this sits just inside the battery box.
I have my LED front spots switched off a relay in the drivers side front wing and wired with 2.5mm cable (live and earth) back to my aux fuse board under the drivers seat. I'm sure that I can get a better route between the 2 headlight units, just not sure what yet. Keith |
That is the best option for the Puma too. ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I'm not sure to alternator would be the best spot though for fault finding if the fuse went and say someone was tracing it for you.
Also not waterproof, but then again suppose none of it is. Personally I'd use larger grade cable so no voltage loss and go back to battery, to do a proper job fit a fuse box in too. None, the less no right or wrong was everyone's personal choice. Who has measured their Puma headlight voltage? Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
