![]() | Home > Puma (Tdci) > 0234 Turbo Overboost |
After I've been driving an hour or so, seemingly when I'm going downhill my car goes in to limp and the ultrgauge (usually) comes up with error 0234 which my IIDTool says is Turbo Overboost.
Any idea what I should be looking at? Other symptoms are that is sometimes sounds a bit rough/rattly under partial throttle although some days is really quiet, and there's a dead spot around 2300 rpm when you're accelerating. EGR is disabled. VCV? |
pdv Member Since: 07 Feb 2014 Location: Asse Posts: 26 ![]() ![]() ![]() |
Hy got same problem anybody an idea
Cheers ![]() |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
Maybe a stiffy linkage/motor adjustment of turbo-guide vanes?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Turbo linkage would be worth checking.
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
TECHNICAL BULLETIN
LTB00393 29 JUN 2011 . SECTION: 303-04B Turbocharger Actuator Arm - Lower Level Repair AFFECTED VEHICLE RANGE: Defender (LD) - 2.4L Puma Diesel Only Model Year: 2007 Onwards VIN: 7A732615 Onwards MARKETS: All Except NAS CONDITION SUMMARY: Situation: A customer may report a concern of restricted engine performance and or a Check Engine Lamp displayed in the Instrument Pack. Following diagnosis trouble codes (DTCs) P0234 or P0299 may be stored in the Powertrain Control Module. If the turbocharger actuator arm movement appears to be restricted due to corrosion of the actuator rod and pins a repair kit is now available. Cause: Turbo actuator arm corrosion may cause restricted movement of actuator arm travel. Suggested Customer Concern Code - D42. Action: Should a customer express concern, follow the Service Instruction outlined below. PARTS: LR019905 Actuator arm 1 LR029042 Grease 1 WARRANTY: noteNOTE: Repair procedures are under constant review, and therefore times are subject to change; those quoted here must be taken as guidance only. Always refer to TOPIx to obtain the latest repair time. noteNOTE: DDW requires the use of causal part numbers. Labor only claims must show the causal part number with a quantity of zero. DESCRIPTION SRO TIME CONDITION CODE CAUSAL PART Install a new Turbocharger Actuator Arm 19.42.79 0.6 hours 69 LR018396 Read and clear DTCs 12.90.16 0.2 hours noteNOTE: Normal Warranty procedures apply. SERVICE INSTRUCTION: 1. Read and clear DTCs. 2. Install a new Turbocharger Actuator Arm (see TOPIx Workshop Manual, Defender 2.4 Puma - 303-04B). Last edited by bell-auto-services on 6th Sep 2016 7:36pm. Edited 1 time in total |
P0234-00 Turbocharger/supercharger A overboost condition - No sub type information
NOTE: The temperature and manifold absolute pressure sensor (TMAP) has registered an over-boost pressure condition Fault affecting intake or boost air circuits Temperature and manifold absolute pressure sensor circuit fault Temperature and manifold absolute pressure sensor component internal failure Actuator-vane variable geometry turbocharger actuator arm mechanical fault Actuator-vane variable geometry turbocharger internal failure Check the intake air path and boost air path for faults including leaks, blockages, and control valve actuator malfunctions Check for engine control module related diagnostic trouble codes Check for actuator-vane variable geometry turbocharger actuator arm for ease of movement For additional information, refer to: Turbocharger Actuator Rod (303-04B Fuel Charging and Controls - Turbocharger - ID4 2.4L Diesel, Removal and Installation). Check for actuator-vane variable geometry turbocharger related diagnostic trouble codes |
