Home > Puma (Tdci) > 0234 Turbo Overboost
Cupboard
After I've been driving an hour or so, seemingly when I'm going downhill my car goes in to limp and the ultrgauge (usually) comes up with error 0234 which my IIDTool says is Turbo Overboost.
Any idea what I should be looking at?
Other symptoms are that is sometimes sounds a bit rough/rattly under partial throttle although some days is really quiet, and there's a dead spot around 2300 rpm when you're accelerating.
EGR is disabled.
VCV?
Post #527792 29th Apr 2016 1:39pm
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hy got same problem anybody an idea
Cheers Thumbs Up
Post #558708 24th Aug 2016 8:27pm
hornet
Maybe a stiffy linkage/motor adjustment of turbo-guide vanes?
Post #561811 6th Sep 2016 10:32am
Turbo linkage would be worth checking.
Post #561821 6th Sep 2016 11:23am
Helstoon
United Kingdom 1997 Defender 90 300 Tdi HT Tamar Blue
Hello,
Just had the same problem with my new to me 2008 90,when accelerating uphill the revs dropped and speed was limited to 30mph. The garage did tell me when I bought it that it was a potential issue that may improve with use ( it had been dried stored for 3 years prior to refurbishment ), it didn't, so they had it back and replaced the turbo with a new one, the power is now where it should be.
Hope this helps
Paul
Post #561963 6th Sep 2016 7:24pm
bell-auto-services
TECHNICAL BULLETIN
LTB00393
29 JUN 2011
SECTION: 303-04B
Turbocharger Actuator Arm - Lower Level Repair
AFFECTED VEHICLE RANGE:
Defender (LD) - 2.4L Puma Diesel Only
Model Year:
2007 Onwards
VIN:
7A732615 Onwards
MARKETS:
All Except NAS
CONDITION SUMMARY:
Situation: A customer may report a concern of restricted engine performance and or a Check Engine Lamp displayed in the Instrument Pack. Following diagnosis trouble codes (DTCs) P0234 or P0299 may be stored in the Powertrain Control Module. If the turbocharger actuator arm movement appears to be restricted due to corrosion of the actuator rod and pins a repair kit is now available.
Cause: Turbo actuator arm corrosion may cause restricted movement of actuator arm travel. Suggested Customer Concern Code - D42.
Action: Should a customer express concern, follow the Service Instruction outlined below.
PARTS:
LR019905
Actuator arm
1
LR029042
Grease
1
WARRANTY:
noteNOTE: Repair procedures are under constant review, and therefore times are subject to change; those quoted here must be taken as guidance only. Always refer to TOPIx to obtain the latest repair time.
noteNOTE: DDW requires the use of causal part numbers. Labor only claims must show the causal part number with a quantity of zero.
DESCRIPTION
SRO
TIME
CONDITION CODE
CAUSAL PART
Install a new Turbocharger Actuator Arm
19.42.79
0.6 hours
69
LR018396
Read and clear DTCs
12.90.16
0.2 hours
noteNOTE: Normal Warranty procedures apply.
SERVICE INSTRUCTION:
1. Read and clear DTCs.
2. Install a new Turbocharger Actuator Arm (see TOPIx Workshop Manual, Defender 2.4 Puma - 303-04B).
Post #561972 6th Sep 2016 7:33pm
bell-auto-services
P0234-00 Turbocharger/supercharger A overboost condition - No sub type information
NOTE: The temperature and manifold absolute pressure sensor (TMAP) has registered an over-boost pressure condition
Fault affecting intake or boost air circuits
Temperature and manifold absolute pressure sensor circuit fault
Temperature and manifold absolute pressure sensor component internal failure
Actuator-vane variable geometry turbocharger actuator arm mechanical fault
Actuator-vane variable geometry turbocharger internal failure
Check the intake air path and boost air path for faults including leaks, blockages, and control valve actuator malfunctions
Check for engine control module related diagnostic trouble codes
Check for actuator-vane variable geometry turbocharger actuator arm for ease of movement
For additional information, refer to: Turbocharger Actuator Rod (303-04B Fuel Charging and Controls - Turbocharger - ID4 2.4L Diesel, Removal and Installation).
Check for actuator-vane variable geometry turbocharger related diagnostic trouble codes
Post #561974 6th Sep 2016 7:34pm
