Home > My Defender > V8 90 Project |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
^^ cheers, it's all a waiting game for the etch primer to "bite" now, I should get the chassis painted prior to going away. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
25th Aug 2016 10:50am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
Great progress Mash, looking good 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
25th Aug 2016 7:39pm |
So today was the day, primer has cured nicely and the top coat was ready to go on.
I read the data sheet instructions and mix the paint 4:1 with the hardener, I then spend 20min adjusting the gun in every possible combination to get a nice consistent spray, could I do it? Could I ! Now do I give up or crack on? Time running out until I go and I have a full gun of paint,........ I'm going for it, paint coming out with a little orange peel effect but hopefully it will dry nicely. So I get 3/4 of the chassis painted and run out of paint, mix myself a new batch exactly the same 4:1 ratio (doing this in paint pots so I know I'm doing it correctly) and what does this paint do first pull of the trigger? It comes out perfectly a nice steady coat, even and no orange peel effect so I finish it off and then go over a few areas to try and even out the coating, making sure I get a good amount of paint inside the outriggers and the rear crossmember. Fingers crossed it looks good once dry fully cure time is up to 7 days as I have used Jotun hardtop flexi a marine 2pac paint so hopefully this will last a long time. Now you have read all that here's the pics you all want. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
26th Aug 2016 8:20pm |
Keeper. Clayton. |
27th Aug 2016 8:32pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Great to follow this as I still have it to do with mine
Keep it up |
28th Aug 2016 10:12am |
Nice easy job today, with the "holiday" looming and everyone back into work tomorrow the chassis needed to move.
So off to the little lock up I have with it, did manage to scratch it in a couple of places and noticed a few missed areas so a second coat will happen with the chassis hanging from a different angle to try and get the missed areas. Here's the chassis in its new home, the last update I will do for a while Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
29th Aug 2016 1:28pm |
Well I'm now back and can continue on with the V8
A few parcels have arrived since I have been away so had a spare hour today and got some bits out for a T-wash; Click image to enlarge Click image to enlarge Also my shinny bulkhead has arrived so I shall be making a start on that this weekend. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
24th Feb 2017 5:56pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Nice! Good to see you back on it
24th Feb 2017 6:38pm |
Cheers Greeni 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
24th Feb 2017 6:39pm |
Back in again today and spent time turning a shinny bulkhead:
Click image to enlarge Into a not so shinny one: Click image to enlarge This is from Ashtree, there are a few minor issues but nothing I can rectify, I have to say their service was very good and I was kept updated regularly even during their move. Hopefully tomorrow I can start the painting process on a few bits. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
3rd Mar 2017 7:09pm |
Nothing worse than blingy Galv.
3rd Mar 2017 7:23pm |
With my move fast approaching and still having to fit in some holidays in between I have managed to get a few bits done today.
Started to get the bulkhead painted with etch primer along with some suspension bits and the gearbox cross member. Click image to enlarge Click image to enlarge Click image to enlarge Also made a start on fitting the large collection of accumulated spares and upgrades into the back of the 90, how have I managed to buy so much 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
11th Mar 2017 8:37pm |
So back off course for the weekend and managed to get a little bit more done on Maggie.
The main thing I wanted to do was finish off the primer on the bulkhead; Click image to enlarge Click image to enlarge With that done I thought I'd spend a little time tarting up some of the engine ancillaries; Click image to enlarge Click image to enlarge Once I finished the above I moved on to sorting out my garage ready for the move, how do you accumulate so much stuff whilst doing a project? How I'm going to move all this stuff I don't know but it will be interesting 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
18th Mar 2017 6:52pm |
Good luck with the move, it's a shame Maggie isn't in one big moveable chunk
18th Mar 2017 7:34pm |
