Home > Maintenance & Modifications > Rear recovery point |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2229 |
If you want a bolt on one, have a word with Clive at Blacksheep. Not sure if he is still on here (pressbrake was is username). He has some photos of his on his facebook page. Look good any will do the job, wouldn't trust some of the cheap ones.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
19th Aug 2016 3:21pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Dixon bate ball & pin. 3.5T
19th Aug 2016 4:10pm |
Fellrunner Member Since: 28 Sep 2014 Location: Wandering Posts: 257 |
Mmm, maybe that's the way to go - I do like the extended tow ball option I use though to get the bike carrier around the spare wheel. The Dixon ball plate looks like a v strong option however.
Click image to enlarge |
19th Aug 2016 4:25pm |
If it's all rated the same then I can't see any reason not to use both.
If you did you'd need to use it I would be careful that your pull is not at an angle however. Or just un-bolt, 5min job providing you don't swap ever week or so. I used mine to pull out a fully loaded van before, no problem at all. And of course I tow using the ball too. Attachment wise, it's just slipping the pin out and replacing, couldn't be easier. |
19th Aug 2016 4:34pm |
Thanks Steve
That does look like a tempting route. I would probably ditch the extender I currently have on though (holding the weight of a bike is one thing, but recovering something with the extender acting as a big lever would make me nervous). |
19th Aug 2016 5:04pm |
19th Aug 2016 7:53pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
I know this has come up before, but is that stainless hardware bolting the NAS step to the crossmember?
19th Aug 2016 8:38pm |
