Home > Maintenance & Modifications > Rear recovery point
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
Rear recovery point
Hi All
I know there's a huge amount relating to recovery points, but I have a very specific question please.
I have a 110 with a NAS rear step, rear cross member in perfect condition.
I'd like to have a rear recovery point. I'm not planning on dragging vehicles windscreen wiper deep out of mud pits, but would like the ability to recover/tow if required.
Jate rings seem like a good option; but a faff to get to. I keep an extended tow ball on the car for pedal bike carrying duties; so it's not really an option to think about tow point related options.
That would leave something like the Terrafirm fixed recovery point option, bolted directly to the rear cross member (I see they do a swivel weld on option, but I'd rather simply bolt on if possible). Can anyone 'vouch' for these, and do they simply bolt on to the original cross member without required modification?
Many thanks
Post #557238 19th Aug 2016 3:15pm
rallysteve
If you want a bolt on one, have a word with Clive at Blacksheep. Not sure if he is still on here (pressbrake was is username). He has some photos of his on his facebook page. Look good any will do the job, wouldn't trust some of the cheap ones.
Post #557247 19th Aug 2016 4:21pm
Dixon bate ball & pin. 3.5T Thumbs Up
Post #557256 19th Aug 2016 5:10pm
Fellrunner
Mmm, maybe that's the way to go - I do like the extended tow ball option I use though to get the bike carrier around the spare wheel. The Dixon ball plate looks like a v strong option however.
Post #557259 19th Aug 2016 5:25pm
If it's all rated the same then I can't see any reason not to use both.
If you did you'd need to use it I would be careful that your pull is not at an angle however.
Or just un-bolt, 5min job providing you don't swap ever week or so.
I used mine to pull out a fully loaded van before, no problem at all.
And of course I tow using the ball too.
Attachment wise, it's just slipping the pin out and replacing, couldn't be easier.
Post #557261 19th Aug 2016 5:34pm
Fellrunner
Thanks Steve
That does look like a tempting route. I would probably ditch the extender I currently have on though (holding the weight of a bike is one thing, but recovering something with the extender acting as a big lever would make me nervous).
Thumbs Up
Post #557266 19th Aug 2016 6:04pm
Thumbs Up
Post #557306 19th Aug 2016 8:53pm
miker
I know this has come up before, but is that stainless hardware bolting the NAS step to the crossmember?
Post #557318 19th Aug 2016 9:38pm
