Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change
Page 7 of 14 <123 ... 678 ... 121314>
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Just done my gearbox. 90XS 2016
8mm hex on drain and filler. Used the plastic pipe to feed down from the engine compartment tip
which worked a treat Very Happy
Fuchs Titan Sintofluid from Opie
Drained out just under 2.2ltr of oil which was in from new, so JLR quality control on the later
year models has certainly kicked in.
Post #549295 17th Jul 2016 12:07pm
Leaky 110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
This thread saved me loads of time doing the initial service after I bought my 2.4, well done to all contributors!
I ended up having to improvise as I couldn't get the little pump for the oil. With the help of an extra pair of hands I fed a small bit of rubber fish tank tube from the filler holes up through the engine bay to a small funnel. Took a wee bit longer but a much cheaper solution and really simple if you don't have a pump handy.
Post #549436 17th Jul 2016 11:20pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi all,
What is outside diameter of the rubber tube ?
Thanks
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #554176 7th Aug 2016 6:51am
Leaky 110
Tried finding the tube in the garage...... No idea! It's roughly the same spec as a garden hose. As long as you can fit it into the filler hole at one end and insert a small funnel into the other you'll be fine. I only used clear tubing so u could see the fluid going in, garden hose would have done in a pinch.
Post #554681 9th Aug 2016 9:19am
MartinK
The filler hole is about 13mm, so you need a pipe of less diameter to fit Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #554687 9th Aug 2016 9:46am
MartinK
While I am on - anyone thought about a X ENG magnetic drain plug to catch any swarf (and therefore give an early warning of any issues)?
http://foundry4x4.co.uk/index.php?route=pr...duct_id=64 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #554688 9th Aug 2016 9:47am
Phil VM2.5
Thanks for the answer
Thumbs Up
1987 BMW GS80
Post #554700 9th Aug 2016 10:55am
JBC
Just followed this guide to replace all my oils, which I got from Opie and were to the spec detailed by others in this post. I also changed the air and fuel filters too as these are easy to do and relatively cheap. Gives me peace of mind that all aspects of a service are now new.
Great guide in this post - thanks to all contributors!
One point to note is that my gearbox filler and drain plugs were hex sockets too, and it's a 2013 2.2 puma 110. At least I didn't have to go and buy a 5 torx bit! There seems to be some variation here so worth checking what you have before you start. There is also some variation in the quantities of lubes required. I went by my owners handbook on page 101. Perhaps LR varied the capacity for the 2.2?
Thanks again
Jon
Post #560853 2nd Sep 2016 4:30pm
Forestman1
Sweden 2011 Defender 110 Puma 2.4 SW Galway Green
I really enjoyed this thread!!
I have only one problem from my oil filling this summer:
I was able to put in much more oil than the 2.2 litres in my gearbox until it overflowed.
There was no levelplug around the gearbox and because of that I thought the box should
be filled until overflow.
Now I´m having trouble with noise and "clunks" from the driveline or gearbox when
starting on low gear and reverse. (no issue when driving on higher gears)
Theres is also an oil leak between the front diff and the propshaft.
(The Defender has only run 85000 km)
First:
Is there a serious troble if the gearbox gets to high oil level?
Second:
Could my trouble now have to do with too high gearbox oil level? Defender 110 SW S, 2011, Galway Green
Post #574719 1st Nov 2016 10:23am
MartinK
Forestman - I would drop the oil from the gearbox asap, and refill with the correct quantity
Hopefully your problems will cease, otherwise you may have blown a seal...
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #574921 2nd Nov 2016 9:02am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I seem to be making a habit of reviving old threads - but thanks very much for the advice in this thread, given me a good idea of DIY maintenance on the Defender.
With regard to grease UJs, is there a nipple fitted - which grease is preferred?
thanks! Bow down My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #606087 2nd Mar 2017 3:39pm
Emile
Spain 2013 Defender 110 Puma 2.2 SW Fuji White
The MT82 seems to have 2 filler plugs, what happens if you use the one more to the front which has a much better excess?
Post #620755 1st May 2017 1:48pm
Milmur64
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Hello,
I'm new to Defenders and have a Oct 2015 Puma 2.2 with DPF XS with 13k on the clock. Having read all the knowledgeable posts I decided to change the gear box oil and transfer box.
I have managed to identify the outlet plugs, but am struggling to identify the inlet plugs - can someone help me please?
For information I have researched via You Tube and a chap gave a demonstration on a 2.4 TDI, but I don't know if the gear and transfer box layout are the same?
Any help will bee much appreciated.
Regards
Jonathan
Post #643016 10th Aug 2017 7:06pm
Milmur64
Hello,
Regards
Jonathan
Post #643017 10th Aug 2017 7:12pm
The gearbox and transfer box are the same for the 2.2 and 2.4. Darren
Post #643037 10th Aug 2017 7:59pm
