Home > Puma (Tdci) > Gearbox output shaft 2012 Puma |
isv Member Since: 14 Feb 2010 Location: Worcestershire Posts: 8 |
Same thing happened to my 2011 110 a couple months ago... Only 14k gentle miles. Luckily it failed in the hands of an engineer from Land Rover who had been sent to my house on recommendation of my dealer who didn't want me to risk the drive in. Poor chap from LR didn't make it beyond end of my driveway before total failure.
LR were brilliant, couldn't have handled it better. 4pm - I call dealer to discuss concerns about transmission 6pm - Engineer from LR (not dealer) arrives at house 6:30pm - Gearbox failure 11:30pm - Loan car (new Freelander HSE) delivered to house 8:00am - AA truck arrives and winches Defender onboard Shame the product was not built properly in the first place...but cannot fault the way LR handled it to be honest. |
14th Jul 2013 6:22am |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
I think the Ford Transit has about the same weight as a Defender.
There is one model with the same 2.2TDCi which weighs 2140kg and has a load capac. of 860kg. But I think this model is a bus, When I see Transits they are driven like they were stolen by underpaid and overworked parcel service drivers. Itīs astonishing (to me) that a gearbox shaft should work there but not in a Defender. OTOH the late Volkswagen Polo of my wife had screws in the wheel well on which I could see the zinc plating even after the 5 years of daily commuting. When I took very new zinc plated screws and put them somewhere on my RRC they were rusty after as much as only one year. So I conlcude that the LR products must be under a kind of curse. Parts that withstand every usage thrown at them will fail if attached to the Defender ? |
15th Jul 2013 10:03pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Yes but transits don't have a transfer box and hence no requirement for the main [to transfer box] intermediate shaft. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
15th Jul 2013 10:16pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
When this problem occurs what parts need replacing and is it just remove the transfer box fit parts and replace transferbox?
Are the parts TUD500020 Shaft LR030054 Collar/Flange I see the LR030054 was a new version introduced after BA555554 chassis numbers so maybe LR believe this is the faulty part? |
16th Jul 2013 10:38am |
2dae Member Since: 21 Sep 2013 Location: Maudsland Posts: 27 |
Hi all
Got the transfer case out to do a inspection Has any one got any info re gearbox shaft to transfer case I heard they might run dry ?? How do i check while trans case is out Dont wont it back in if all not right as im only tring to find a weried noise in low gear |
23rd Oct 2013 10:46am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
I was told by the stealer that there's no requirement for that shaft to be greased. I'm not impressed with that as a couple of cents worth of grease can't do any harm.
AlanH. |
23rd Oct 2013 11:04am |
hamster Member Since: 27 Apr 2013 Location: suffolk Posts: 6 |
Mine went on my2011 22000 miles along with clutch, Now clunk free
Regards Paul |
23rd Oct 2013 6:22pm |
Tony Member Since: 13 Mar 2012 Location: West Yorkshire Posts: 72 |
Mine went a couple of days ago, July '12 car with 16,000 very carefully driven miles on it. The garage called today to say I can pick it up tomorrow, it's had a clunk in the transmission from new so fingers crossed that might be better now too! Loan car has been a Disco HSE Luxury; nice car but far too many knobs and buttons in it - can't wait to get the Defender back!
Cheers! |
24th Oct 2013 8:30pm |
Put transfer case back in seems ive still got that first gear whine
Although might have found a loose nut on the front output shaft which may have been causeing a vibration at 75 k/m ph The guys might have not tightened to correct tension Will pull out front shaft and check tension Good help hard to find |
31st Oct 2013 11:08am |
Pleased to say the gearbox is so much better now with the new shaft fitted, and having also had the transfer box front output seal replaced earlier in the month it is now 'leak and clunk free' - amazing! |
31st Oct 2013 11:47am |
richardd Member Since: 01 Aug 2012 Location: Glasgow, sort of Posts: 21 |
Me too!
started with a big clunk then got worse over 3 or 4 miles before failing near my parent's house. The 2 hour wait for assistance was not too onerous - got a nice lunch! The gearbox end splines are a) too fine and b) sometimes not greased enough at assemby. The Tech who fixed mine assured me it was now properly greased. MY2012 110XS with 19k miles. Other than that my 110 gets driven hard, never washed, regularly running off road (I have a smallholding) and frequently tows 3t plus. So far I've had a leak at the bulkhead, a wee bit of rust (literally a spot) fixed due to bad assembly (it was a weld that was not flattened before painting) and that's it. Having had a couple of freelanders as courtesy cars I now want my nex car to be a Defender with a Disco interior and gadgets - heated steering wheel mmmmmmmmm |
8th Nov 2013 11:43am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3479 |
My 130 started to whine and had loads of slack in the drivetrain...... took it into one dealer and they replaced a swivel seal under extended warranty. Said the rest was fine. I took it for another opinion.
Took it to a dealer who knows Defenders and more importantly understands the issues. Call today to say they are replacing output shaft, transfer box, new rear diff, all half shafts. They are also fixing the water leak, fitting a new front bumper and painting the windscreen surround and both bulkhead brackets. While they have the box out, I am wondering if I should ask for the clutch to be done? 39k miles. Discuss ! 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
15th Jun 2016 5:28pm |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 |
Thats a huge difference in stealer coverage... PM me the dealership details as I may use them in future since I have hatred for my local one...
15th Jun 2016 5:40pm |
Might be a bit far....
Chipperfield LR, Herts 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
15th Jun 2016 5:41pm |
