Home > Puma (Tdci) > Gearbox output shaft 2012 Puma
Page 1 of 3 123>
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
During a trip to Germany, in fact on my way to the Allrad show in Bad Kissingen I lost drive and the vehicle was recovered back to my dealer in Oxford. They have told me the shaft from the gearbox to transfer box failed and will need replacing, fortunately under warranty. I am surprised considering the truck has only covered 14,000 miles.
Is this a common problem and has anybody else experienced shaft failure on such a low millage vehicle.
Sadly all I have done since owning the truck is take it back to the dealer with issues.
I would also be interested to hear if anybody has been successful in rejecting their Landrover and getting their money back?
Post #246681 25th Jun 2013 5:47pm
bob neville
Getting more common by the day Big Cry
Think I was the first to report the failure last year on my 2009 2.4 110 and there have been a few more since then, one very recently.
I rejected my first 110 in 2009 but after a month. LR build quality is not the best but that one set new standards Laughing It was replaced by another 110 by LR and they were like chalk and cheese Thumbs Up
You must give LR a chance to resolve issues, especially with 14K on the clock. If that fails then you will need to engage LR themselves, not an easy task.
Good luck
2013 Defender 90 CSW - sold
Post #246693 25th Jun 2013 7:02pm
Howard
Bob, thanks for the response.
Howard
Post #246695 25th Jun 2013 7:14pm
bob neville
Thumbs Up
Here is my original post last year.
http://defender2.net/forum/topic11955.html
Post #246699 25th Jun 2013 7:38pm
miket
This happened to me last week (see http://defender2.net/forum/topic21166.html ) and is now all sorted. The independent LR garage I went to said they hadn't seen this failure before.
Bloody thing was only 8 weeks out of warranty so I had to pay for it out of my own pocket. I'll be sending a letter to Land Rover though...
Mike
Post #246710 25th Jun 2013 7:59pm
Caterham
yep - I'm a member too.
shaft went at c 22k miles (c2yrs)......and I drove it like a fairy.
had one or two other issues (won't bore you with)......might having nothing to do with the shaft but I ended up with a new gear box shortly after the replaced shaft. ??
2yrs from new and it would appear everything has been ironed out ( Shocked what have I just said - somthing is gonna go wrong now isn't it Thud )
Post #246792 25th Jun 2013 9:45pm
schuee
Mine has developed a gradual whine from the Transfer Box since nearly new, dealer has been notified and has suggested to me to keep an eye on it Whistle Anyway doesn't seem to affect the day to day driving so will see what happens.
Post #246893 26th Jun 2013 9:34am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Yep mine went comon fault the splines are to fine
Post #247303 27th Jun 2013 8:30pm
Caterham
the splines are too fine ?
I'm not saying they aren't but given some of the high mileage one that have been ok then I presume they much be adequate (if only just?)
there must be something more than a design issue for them to fail in c20k (of very gentle driving) and other to exceed 200k without a problem?
Post #247367 28th Jun 2013 5:45am
It's been suggested before that faiure is due to inadequate lubrication on assembly, which would explain the apparently random failures. Darren
Post #247369 28th Jun 2013 6:15am
miket
I've still got the parts that failed, and looking at them it's clear that the splines are not evenly worn. The splines on the end look perfect while most look pretty worn away. This makes me wonder if incorrect fitting is part of the problem, leading to a smaller area of the splines bearing an excessive load, leading to increased failure?
Post #247382 28th Jun 2013 7:36am
AlanH
Australia
The stealer here has just fixed the shocking driveline slop in my 2010 and part of the prob was that shaft apparently. Seems to me to be down to bad assembly as are most of the problems with this vehicle.
Certainly doesn't give me any confidence to continue to go to remote areas in it.
AlanH.
Post #247395 28th Jun 2013 9:00am
Caterham
Very Happy same morons that built mine it would seem.
what exactly did they do? (there might be another problem lurking that I've not found yet).
my last issue seemed to be the hand brake drum and shoes not fitted properly together with the empty sandwich packaging left in there from lunch on the assembly line Shocked )
really pleased to hear you've found another fix. hopefully your confidence will soon be restored.
Post #247399 28th Jun 2013 9:16am
keith
For months now I have had terrible back lash and drive problems . All the same symptoms as reported . My dealer took the gearbox out and confirmed splines on this shaft very worn along with other worn parts . New transfer box required and this was 2 wks ago . There are NO transfer boxes in stock at the factory and there is a back order for over 18 vehicles parts . Arrrrrrgh ? I had planned an overland trip to Tbilisi Georgia , leaving this Sunday , guess I'm flying then ? My 110 sits at the dealer as I go away for 6wks with no date known when new gearboxes will arrive . What's new then ?
Post #247507 28th Jun 2013 8:30pm
mick
Yep there Censored one end has strong splines the other small this is to try and get rid of some transmission slop but they are not up to the job on a heavy motor or one that does a lot of towing Thumbs Up
Post #247508 28th Jun 2013 8:31pm
Page 1 of 3 123>
