Home > Camping, Caravanning and Holidays > Sankey MkII Trailer - My refurbishment starts |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
My narrow track has had a simple bracket which extends beneath the handbrake to enable a breakaway cable to be fitted. I will post a picture later as it is a simple way to achieve this requirement. 1995 Defender 110 CSW
1971 SIIA Lightweight |
7th Jun 2016 10:55am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3760 |
^ Your right does not really show it that well
This is better the thinner cable with a carabina type clip on it. Zoomed in from the trailer as I bought it. I'm planning on an extra chain with 'D' clamps also though |
7th Jun 2016 1:12pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17464 |
OK, thanks. I really couldn't spot that!
From your description, am I right in thinking that the trailer end of that cable is attached to the bell crank on the axle? If so, it really doesn't do the job since although the brakes will be applied momentarily, as soon as the cable breaks (which it is designed to do and inevitably will do) the brakes will release again. The cable needs to be attached to the handbrake lever so that once the cable breaks, the trailer brakes will stay hard on. The problem with the Sankey is that there is no obvious simple way of doing this, but hopefuilly Ramsey's photo, when he is able to post it, will show a suitable method. |
7th Jun 2016 1:56pm |
Hello
My first picture is not the best and confusing The breakaway cable is attached to the back of the handbrake with two strange looking connections, will take a better picture as want to make sure its right |
7th Jun 2016 2:40pm |
In that case all may be well, but if you can post a pic when you get the chance we'll take a look and give an opinion!
7th Jun 2016 2:59pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
I have the same thing on my MKIII Sankey the breakaway cable attaches to the handbrake mechanism which is on a ratchet so once pulled on needs to be released manualy.
Thanks for the explanation blackwolf I think I should maybe get a chain now as a further backup. |
7th Jun 2016 3:38pm |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
I have this setup but think will also add a breakaway cable attached to the rear of my hitch plate and onto the lower swing arm of the hand brake mechanism. When this pulls tight the brakes will apply. I will make sure that the length of the cable is less than the chain.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
7th Jun 2016 7:39pm |
Have you a picture? Was it added at a later date? |
7th Jun 2016 7:41pm |
^ that was my sort of idea as an extra saftey measure.
I have this breakaway currently is this attached correctly as I've done nothing with this but have a new cable ready to fit. Click image to enlarge Click image to enlarge |
7th Jun 2016 8:04pm |
yes my thoughts exactly. At least if the unthinkable happens the cable will pull on the brakes (my ratchet handle doesn't really engage properly so once snaps may no longer engage brake) however chain will hopefully keep it attached to the Landy pending emergency brown-trousers stop!
7th Jun 2016 8:44pm |
Just make sure that pulling on the breakaway cable applies the handbrake ratchet so the brakes stay on.
I sold my narrowtrack some years ago (unfortunately) so am working from memory, but I think the lever your cable is on in the photo above is the lever that the back end of the lunette pushes on, in which case although pulling on the breakaway will apply the brakes, they won't stay on when the cable snaps. If so, this does not meet the requirement. If I recall correctly you have to extend the handbrake lever itself downwards below the pivot on a narrowtrack in order to have a suitable attachment point. |
7th Jun 2016 10:00pm |
Today finally managed to get some stuff done on the Sankey. Happy days. Chain hoist from Lidl did all the hard work!
11th Jun 2016 11:10pm |
Managed an hour today to do a few little jobs...
Used some Discovery mudflaps Click image to enlarge Fitted ok, and should 'do the job' Click image to enlarge Fitted my 8mm plastic cover plate to original number plate holder. Click image to enlarge Then my kids School were throwing 3 large mats out.... I've used 2 for now in the tub. Will cut round the anchor points. Click image to enlarge Still need to sort the wiring from 24v to 12v, I've decided to use a junction box so have one on order |
11th Sep 2016 8:28pm |
OK so the job I've been putting off will have to be done soon as this turned up....
Click image to enlarge Click image to enlarge Nato 24v in one end and then 12v out the other. That's the theory.... aarrgghh |
13th Sep 2016 7:55pm |
