Home > Puma (Tdci) > Speed Sensor Wiring
Morepower
New Zealand
Speed Sensor Wiring
Hi Guy's... Does anyone know which wire (colour) is the signal wire for the speed sensor mounted on the transfer box (2013my 110)
Thanks in advance
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #531522 14th May 2016 5:00pm
Fifth Horseman
Three wires to the speed transducer:
1. +12v ignition - white/green
2. Earth - black
3. Speed pulse - black/red
Also available at pin 13 of the instrument pack connector.
Post #531626 15th May 2016 7:16am
Someone's fitting cruise control Thumbs Up
If you want an ignition live, take the white one off the ignition switch, sounds worse than it is, pretty easy to get to
Post #531629 15th May 2016 7:30am
Morepower
New Zealand
Thanks Guys... Yes I am... Just making up small sublooms so it can be removed if it goes faulty... Not a great fan of soldering joints and modifying the std loom... I've been trying to get around to fitting this for about 18 months... So I'm hoping to get it done today..
Post #531667 15th May 2016 9:17am
