![]() | Home > Puma (Tdci) > Speed Sensor Wiring |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 330 ![]() ![]() ![]() |
Three wires to the speed transducer:
1. +12v ignition - white/green 2. Earth - black 3. Speed pulse - black/red Also available at pin 13 of the instrument pack connector. |
Someone's fitting cruise control
![]() If you want an ignition live, take the white one off the ignition switch, sounds worse than it is, pretty easy to get to |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Thanks Guys... Yes I am... Just making up small sublooms so it can be removed if it goes faulty... Not a great fan of soldering joints and modifying the std loom... I've been trying to get around to fitting this for about 18 months... So I'm hoping to get it done today..
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
