Home > Puma (Tdci) > Prop shaft play |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 504 |
Gents
The Landrover man is telling me that there is too much play in the 110s prop shaft and that the transfer box shaft thingie is goosed ( I think that he's right) but how much play should there be, just so I can check Thanks Wes Oh woe, oh woe My crusty old landrover, It will not go. |
16th Apr 2016 7:10am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
If you are on about propshaft yokes, there should be no play in them, sometimes a small amount of play can be taken up by greasing, the problem is a lot of people neglect the props and fail to grease them, this leads to premature wearing of the bearings inside the yokes. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
16th Apr 2016 8:41am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6295 |
I'm no expert but can't see how without taking the gearbox apart he can determine the transfer box shaft thingie is goosed - assuming he's referring to the well known problem of the extension shaft / adapter shaft? good luck whatever - remember in terms of rotational slack there always appears to be quite a bit. |
16th Apr 2016 10:16am |
Get underneath and ask him to show you what he means, there's only one way to learn for yourself - get your hands dirty and feel the play for yourself.
16th Apr 2016 10:59am |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
is there not and inspection plate with 6 bolts on that is easily removable? My 109 thread my youtube channel |
17th Dec 2016 4:37pm |
For the transfer gears yes but not the extension / adapter shaft.
17th Dec 2016 4:45pm |
17th Dec 2016 5:03pm |
