Home > Puma (Tdci) > Prop shaft play
Mother superior
Prop shaft play
Gents
The Landrover man is telling me that there is too much play in the 110s prop shaft and that the transfer box shaft thingie is goosed ( I think that he's right) but how much play should there be, just so I can check
Thanks
Wes Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #524395 16th Apr 2016 7:10am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If you are on about propshaft yokes, there should be no play in them, sometimes a small amount of play can be taken up by greasing, the problem is a lot of people neglect the props and fail to grease them, this leads to premature wearing of the bearings inside the yokes. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #524410 16th Apr 2016 8:41am
Retroanaconda
Should be no play in yokes as above. And no play in propshaft sliding joint (though a little won't cause too much of a problem). The front output flange of the transfer box is supported by a straight ball bearing, so a little radial play in that is normal. Should be no play in the rear one.
Rotational play - i.e. driveline slop - some is normal. Depending on the wear in downstream components there can be up to 1/4 turn, this will cause clonking etc. but won't actually fail dramatically. Though it can increase wear on the propshaft joints themselves.
Post #524411 16th Apr 2016 8:46am
Caterham
Re: Prop shaft play
Mother superior wrote:
Gents
Thanks
Wes
I'm no expert but can't see how without taking the gearbox apart he can determine the transfer box shaft thingie is goosed - assuming he's referring to the well known problem of the extension shaft / adapter shaft?
good luck whatever - remember in terms of rotational slack there always appears to be quite a bit.
Post #524439 16th Apr 2016 10:16am
Get underneath and ask him to show you what he means, there's only one way to learn for yourself - get your hands dirty and feel the play for yourself.
Post #524445 16th Apr 2016 10:59am
g-mack
Re: Prop shaft play
is there not and inspection plate with 6 bolts on that is easily removable? My 109 thread
my youtube channel
Post #585813 17th Dec 2016 4:37pm
Caterham
For the transfer gears yes but not the extension / adapter shaft. Thumbs Up
Post #585814 17th Dec 2016 4:45pm
g-mack
Post #585816 17th Dec 2016 5:03pm
