![]() | Home > Puma (Tdci) > Screeching noise and Check engine light |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Hi all,
I knew I was being too smug, having done 4000 miles in two months on the 110 (making 8500 in total), with nary a problem (apart from the usual small niggles like door adjustment and minor leak!) Was on my way to see my brother yesterday, when, after a 2.5 hour motorway journey and coming into London, my check engine light illuminated. I also noticed that this seemed to coincide with an intermittent (And not too loud) screech when acceerating from rest (sounds a bit like a fanbelt slipping but only lasts 2-3 seconds and goes). Anyway, it was late at night, and being miles from home, I was in a rush, so plugged in my BAS box, and instead of reading fault codes, just cleared them (not very helpful, I know, but my logic was that if the fault was major the light would illuminate again!) Since then, the light hasn't come on again but I have had a couple of brief reoccurrences of the screech. Any ideas, and would it trip the light, or something else? If it does it again, I'll call LR assist, I think, just to be safe! ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 Last edited by szracer on 18th Jan 2011 7:40pm. Edited 2 times in total |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
What about taking off the EGR closed map and putting it to standard first (you can put it all back on cant you) Mike
Cheers, Mike.
I may even put the standard LR map back on again, and drive it for a while, just to see. Then if the light does go on again, at least I feel happier with the LR assist bloke plugging any diagnostic equipment in. IN mean time, will have a good look under the car and under the bonnet tomorrow! ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
Should imagine, yes - although obviously not if the suspension falls apart!
In theory, the remap should be fully reversible.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
Screech on acceleration could be the early indications of a leak in the turbo to intercooler hose, probably caused by the hose rubbing on the steering column adjacent to the steering box. I believe that this can cause MIL activation if it results in the turbo overspeeding.
Your noise - like a fanbelt slipping - sounds exactly like the noise I had when I suffered the above hose failure. Pressing the load pedal would make it happen; you could almost play tunes with it. |
Thanks - Think I will need to get the dealer to look at it. Interestingly, I have noticed a strange sound (almost like the ABS kicking in) when pulling away with steering lock applied). Maybe related?
Did a read of the diagnostic codes this morning, and I had the following: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module U0300 - Internal Control Module Software Incompatibility P1643 - CAN Link Engine Control Module/Transmission Control Module Circuit/Network
![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 Last edited by szracer on 18th Jan 2011 7:41pm. Edited 1 time in total |
Send this infos to Pete (Bell Auto Services)....................... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hi all,
Well, the 110 is in with the dealer today, but they seem perplexed. The noise seems to particularly occur (and be repeatable) after having reversed on full lock. When I drive away on gentle throttle, the high pitched whine stays for 30 secs to a minute. No check engine light, but quite a lot of fault codes (and I've been back to the standard engine map for a week or so now - cleared all fault codes too). Any ideas?? Hoping it's not going to be one of those ' ![]() ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
Remove the pipe from the turbo to the intercooler and inspect its underside carefully. If it has been carelessly fitted it will have been rubbing on the pinch bolt on the steering column where the column enters the steering box and will have a flappy type hole in it. Under power it will squeal like a fan belt, full lock will disturb it and make it worse. You will not be able see the hole with the pipe in situ. Access is improved if you remove the air filter housing, but it isn't particularly easy to remove. Alternatively it may be something quite different, but this is easy to check and simple to fix. The hose is about £50 from a main dealer. |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Hi.Check you disc brake mud shield.It might rubbing against the disc or stone wedged in it.Happened to me,and it was a brain teaser to find. Puma 110 SW 90 V8 SOFT TOP |
I have been having a few problems also over the last month and those codes have been on mine too |
As a foot note I checked my faults the night before I took it in to the dealers but i did not clear them. When I arrived back at home having collected it two days later the faults were still there but the dealers said there were no fault
![]() This is what I have logged so far Jan 12th P0100 P1643 U0155 U0300 Left on and delivered to dealers. covered about 60 miles Jan 14th Collect from dealers & read codes P0404 P0100 P1643 U0155 Cleared covered about 25 miles Jan 16th U0155 U0300 P068A P0606 P0404 Cleared Covered about 10 miles Jan 18th P0404 P0101 Thought from now on I will keep a record of what codes and when so if need be see if there is any patern or if anyone else has the same thing. |
Think I can trump that....
![]() Befroe mine went into dealer yesterday, it was showing: P0404 P1103 P0606 P0100 P0234 P1643 U0155 U0300 P0299 P068A Dealer says I need a new ECU!! ![]() Apparently the screech is unconnected, and (they say) caused by a faulty clutch (6 month old vehicle!). We shall see - I'm not 100%...
Did you check the turbo pipe? Mike
