Home > Puma (Tdci) > Screeching noise and Check engine light
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all,
I knew I was being too smug, having done 4000 miles in two months on the 110 (making 8500 in total), with nary a problem (apart from the usual small niggles like door adjustment and minor leak!)
Was on my way to see my brother yesterday, when, after a 2.5 hour motorway journey and coming into London, my check engine light illuminated.
I also noticed that this seemed to coincide with an intermittent (And not too loud) screech when acceerating from rest (sounds a bit like a fanbelt slipping but only lasts 2-3 seconds and goes).
Anyway, it was late at night, and being miles from home, I was in a rush, so plugged in my BAS box, and instead of reading fault codes, just cleared them (not very helpful, I know, but my logic was that if the fault was major the light would illuminate again!)
Since then, the light hasn't come on again but I have had a couple of brief reoccurrences of the screech. Any ideas, and would it trip the light, or something else? If it does it again, I'll call LR assist, I think, just to be safe!
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #52090 9th Jan 2011 11:04pm
mse
What about taking off the EGR closed map and putting it to standard first (you can put it all back on cant you) Mike
Post #52127 10th Jan 2011 12:45am
szracer
Cheers, Mike.
I may even put the standard LR map back on again, and drive it for a while, just to see.
Then if the light does go on again, at least I feel happier with the LR assist bloke plugging any diagnostic equipment in.
IN mean time, will have a good look under the car and under the bonnet tomorrow!
2005 Ducati ST3
1954 Sunbeam S8
Post #52129 10th Jan 2011 12:49am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
out of interest does a remap [BAS or anyother] affect the warranty and LR Assist. yiu can probably guess why i am asking Whistle BM52
Post #52135 10th Jan 2011 12:59am
szracer
Should imagine, yes - although obviously not if the suspension falls apart!
In theory, the remap should be fully reversible.
2005 Ducati ST3
1954 Sunbeam S8
Post #52137 10th Jan 2011 1:16am
Screech on acceleration could be the early indications of a leak in the turbo to intercooler hose, probably caused by the hose rubbing on the steering column adjacent to the steering box. I believe that this can cause MIL activation if it results in the turbo overspeeding.
Your noise - like a fanbelt slipping - sounds exactly like the noise I had when I suffered the above hose failure. Pressing the load pedal would make it happen; you could almost play tunes with it.
Post #52155 10th Jan 2011 11:00am
szracer
Thanks - Think I will need to get the dealer to look at it. Interestingly, I have noticed a strange sound (almost like the ABS kicking in) when pulling away with steering lock applied). Maybe related?
Did a read of the diagnostic codes this morning, and I had the following:
U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
U0300 - Internal Control Module Software Incompatibility
P1643 - CAN Link Engine Control Module/Transmission Control Module Circuit/Network
2005 Ducati ST3
1954 Sunbeam S8
Post #52159 10th Jan 2011 11:28am
dgardel
Italy
Send this infos to Pete (Bell Auto Services)....................... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #52162 10th Jan 2011 12:08pm
szracer
Hi all,
Well, the 110 is in with the dealer today, but they seem perplexed.
The noise seems to particularly occur (and be repeatable) after having reversed on full lock. When I drive away on gentle throttle, the high pitched whine stays for 30 secs to a minute.
No check engine light, but quite a lot of fault codes (and I've been back to the standard engine map for a week or so now - cleared all fault codes too).
Any ideas?? Hoping it's not going to be one of those ' Censored -to-find' type faults!
2005 Ducati ST3
1954 Sunbeam S8
Post #53614 18th Jan 2011 1:07pm
Remove the pipe from the turbo to the intercooler and inspect its underside carefully. If it has been carelessly fitted it will have been rubbing on the pinch bolt on the steering column where the column enters the steering box and will have a flappy type hole in it. Under power it will squeal like a fan belt, full lock will disturb it and make it worse. You will not be able see the hole with the pipe in situ. Access is improved if you remove the air filter housing, but it isn't particularly easy to remove.
Alternatively it may be something quite different, but this is easy to check and simple to fix. The hose is about �50 from a main dealer.
Post #53618 18th Jan 2011 1:51pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
szracer wrote:
Hi all,
Hi.Check you disc brake mud shield.It might rubbing against the disc or stone wedged in it.Happened to me,and it was a brain teaser to find. Puma 110 SW
90 V8 SOFT TOP
Post #53620 18th Jan 2011 1:53pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Did a read of the diagnostic codes this morning, and apart from the usual suspects (triggered by the remap, and nothing to worry about), I had the following:
I have been having a few problems also over the last month and those codes have been on mine too
Post #53621 18th Jan 2011 2:00pm
The Boy
As a foot note I checked my faults the night before I took it in to the dealers but i did not clear them. When I arrived back at home having collected it two days later the faults were still there but the dealers said there were no fault Shocked . I fully accept that the dealers can't see all the faults displaid by the BAS box but I am very unsure whats going on. I am just going to check it again to see if it has thrown any more up since the last time I checked.
This is what I have logged so far
Jan 12th
P0100
P1643
U0155
U0300
Left on and delivered to dealers.
covered about 60 miles
Jan 14th
Collect from dealers & read codes
P0404
P0100
P1643
U0155
Cleared
covered about 25 miles
Jan 16th
U0155
U0300
P068A
P0606
P0404
Cleared
Covered about 10 miles
Jan 18th
P0404
P0101
Thought from now on I will keep a record of what codes and when so if need be see if there is any patern or if anyone else has the same thing.
Post #53726 18th Jan 2011 7:31pm
szracer
Think I can trump that.... Whistle
Befroe mine went into dealer yesterday, it was showing:
P0404
P1103
P0606
P0100
P0234
P1643
U0155
U0300
P0299
P068A
Dealer says I need a new ECU!! Shocked
Apparently the screech is unconnected, and (they say) caused by a faulty clutch (6 month old vehicle!). We shall see - I'm not 100%...
Jan 12th
P0100
P1643
U0155
U0300
Jan 14th
P0404
P0100
P1643
U0155
Cleared
Jan 16th
U0155
U0300
P068A
P0606
P0404
Cleared
Jan 18th
P0404
P0101
2005 Ducati ST3
1954 Sunbeam S8
Post #53863 19th Jan 2011 2:18pm
mse
Did you check the turbo pipe? Mike
Post #53871 19th Jan 2011 2:44pm
