Home > Puma (Tdci) > Screeching noise and Check engine light |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
Not personally, no (It was at the dealers for them to look). They say they checked for chafing etc, but didn't find any.
What I will say is that performance at the moment is very very lacklustre - even for a standard map. Turbo-related? Not wishing to show my ignorance, but where do I look for the turbo pipes?
2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
19th Jan 2011 6:16pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Any news James? Have LR fitted the new ecu? Has it helped?
25th Jan 2011 7:15pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
I remember sometime ago I noticed the steeing column was rubber off the hose that runs just above it,and there was a small chaffing mark on the hose. I put some duck tape around the hose and then used a cable tie to lift the hose clear of the bolt on the steering column. I tied the cable tie to the plastic trunking for the air intake just above it. Job done I thought. Recently I noticed that the main dealer had replaced the rubber hose. The new hose has two white marks at the top of it, which is how I noticed it, so it must be a revised hose. The trunking for the air intake has been pushed out from the inside of the wheel arch and wedged out by a piece of adhesive backed foam block.This keeps everything clear of the bolt on the steering column. This must have been a "fix as they come in directive". My hose was not holed yet the above modification was made. 1982 88" 2.25 diesel
25th Jan 2011 11:44pm |
Ian
I see you are getting U0155 which is lost communication with the instrument cluster. Since early december I have been getting this one too. I have jsut been out to read the latest ones and it was on there again. Off down to Portsmouth tonight so have cleared and will see what is on there again. Boy |
28th Jan 2011 1:10pm |
