Home > Puma (Tdci) > stuck in first gear!
Page 2 of 3 <123>
ashtrans
Site Sponsor
Yes, see post 3 Dave
Post #517108 23rd Mar 2016 7:04pm
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
yes, I saw that, but it didn't fix it which is why they took the box out and opened it up. So hoping to get some other ideas. Thank you.
Post #517125 23rd Mar 2016 7:42pm
ashtrans
Site Sponsor
what gear is it stuck in ?
Dave Dave
Post #517389 24th Mar 2016 1:18pm
Tribord
The garage has unblocked the gear, but thinks there is a broken fork. To continue they need to apply heat which they say can damage the plastic on the bearings. They did ask if I wanted to try and get hold of a replacement gearbox rather than spend more money on labour to investigate/fix this one (which appears to be difficult to estimate until they get in deeper to the box). This gearbox has only done approx 30,000 miles, so my first thought is for them to try and fix this one, but what do others think ?
So sad seeing the defender still in the garage after all these weeks Sad
One positive is they looked at the output shaft - it was dry, but the teeth were fine. They have now applied grease, so one less thing to worry about..
Post #519255 30th Mar 2016 4:31pm
ashtrans
Site Sponsor
Hi,
You don't need heat to strip it, but you do need to make pullers, most garages wouldn't know how to strip and reassemble one of these and I am not convinced these guys do either which may be why they are suggesting you getting a replacement, at 30K it should be in pretty good shape, you can remove the transfer case and send it in to us on a pallet if you would like to, it would be 2-3 days each way and approx £ 200 + vat to fix, + approx £ 80 return carriage
Dave Ashcroft (Ashcroft Transmissions) Dave
Post #519342 30th Mar 2016 8:28pm
Tribord
Is that £80 return carriage to France?
Post #519353 30th Mar 2016 8:37pm
ashtrans
Site Sponsor
yes approx £ 80 + V for me to send it back to you,
Dave Dave
Post #519564 31st Mar 2016 12:39pm
ashtrans
Site Sponsor
sorry if this is too commercial Martin, just trying to help this guy out, maybe we should PM from here,
Dave Dave
Post #519565 31st Mar 2016 12:40pm
Tribord
Yes, and very helpful it is to. I will PM you from now
Post #519604 31st Mar 2016 2:37pm
Jock_Scotland
Scotland 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Mine did this about 20k miles ago, but to be fair I tried to pull it out of gear whilst there was a bit of weight on the box (sat with the engine stopped). Had to pull the detents to sort it - no harm done eh?
Today my local garage have pulled the gearbox to bits to swap the input bearing and discovered severe damage to 3 gears - missing teeth Shocked
Not sure what has done this or even if it's related but beware!
There's plenty more of mess stuck to the magnet in the box but no big chunks of gear. Drove fine, no noise or anything.
New gearbox wanted!
Post #637202 12th Jul 2017 8:07pm
cineson
ashtrans wrote:
This can be fixed in the car,
At the rear left corner of the gearbox you will see 2 detent plugs, one vertical and one horizontal,
Using a small chisel, tap out the vertical one, it has a mushroom head to hit on and is an interference fit,
Once out, poke a small screwdriver into the hole and lever the selector rail to the front of the car about 5mm,
Have a front wheel up and keep rocking it so you know when you are back in neutral,
Then either put the depend back in or better still replace it with the later one which has a stronger spring, will post the part number tomorrow,
Dave
This just saved me a hefty bill on a 2010 90.. many thanks!! Thumbs Up
Post #808252 31st Dec 2019 5:07pm
ashtrans
Site Sponsor
Great, happy to help Thumbs Up Dave
Post #808433 1st Jan 2020 9:40pm
IGGISAIL
Wales 2008 Defender 110 Puma 2.4 XS DCPU Tonga Green
Dave
Can I jump in here and say a Huge thankyou to Dave for sharing this info - drove to work in 1st gear today! read this post, all done by lunchtime - you sir, are a superstar ! Thanks very much Smile
Post #869929 27th Nov 2020 1:52pm
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Glad to hear that Dave's post worked for you too.
Can I ask, how did yours get stuck in first gear?
Thanks,
Dave (the other Dave who asked for help at the start of this thread)
Post #869962 27th Nov 2020 5:30pm
IGGISAIL
Yeah, I knocked it ‘out of gear’ without depressing the clutch..... 🤣
Post #869970 27th Nov 2020 5:48pm
Page 2 of 3 <123>
