Home > Puma (Tdci) > stuck in first gear! |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 |
Yes, see post 3 Dave
23rd Mar 2016 7:04pm |
what gear is it stuck in ?
Dave Dave |
24th Mar 2016 1:18pm |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 |
The garage has unblocked the gear, but thinks there is a broken fork. To continue they need to apply heat which they say can damage the plastic on the bearings. They did ask if I wanted to try and get hold of a replacement gearbox rather than spend more money on labour to investigate/fix this one (which appears to be difficult to estimate until they get in deeper to the box). This gearbox has only done approx 30,000 miles, so my first thought is for them to try and fix this one, but what do others think ?
So sad seeing the defender still in the garage after all these weeks One positive is they looked at the output shaft - it was dry, but the teeth were fine. They have now applied grease, so one less thing to worry about.. |
30th Mar 2016 4:31pm |
Hi,
You don't need heat to strip it, but you do need to make pullers, most garages wouldn't know how to strip and reassemble one of these and I am not convinced these guys do either which may be why they are suggesting you getting a replacement, at 30K it should be in pretty good shape, you can remove the transfer case and send it in to us on a pallet if you would like to, it would be 2-3 days each way and approx £ 200 + vat to fix, + approx £ 80 return carriage Dave Ashcroft (Ashcroft Transmissions) Dave |
30th Mar 2016 8:28pm |
Is that £80 return carriage to France?
30th Mar 2016 8:37pm |
yes approx £ 80 + V for me to send it back to you,
Dave Dave |
31st Mar 2016 12:39pm |
sorry if this is too commercial Martin, just trying to help this guy out, maybe we should PM from here,
Dave Dave |
31st Mar 2016 12:40pm |
Yes, and very helpful it is to. I will PM you from now
31st Mar 2016 2:37pm |
Jock_Scotland Member Since: 15 Mar 2016 Location: The Borders Posts: 12 |
Mine did this about 20k miles ago, but to be fair I tried to pull it out of gear whilst there was a bit of weight on the box (sat with the engine stopped). Had to pull the detents to sort it - no harm done eh?
Today my local garage have pulled the gearbox to bits to swap the input bearing and discovered severe damage to 3 gears - missing teeth Not sure what has done this or even if it's related but beware! There's plenty more of mess stuck to the magnet in the box but no big chunks of gear. Drove fine, no noise or anything. New gearbox wanted! |
12th Jul 2017 8:07pm |
cineson Member Since: 19 May 2019 Location: Yorkshire Posts: 1 |
This just saved me a hefty bill on a 2010 90.. many thanks!! |
31st Dec 2019 5:07pm |
Great, happy to help Dave
1st Jan 2020 9:40pm |
IGGISAIL Member Since: 27 Nov 2020 Location: The 'Port Posts: 2 |
Can I jump in here and say a Huge thankyou to Dave for sharing this info - drove to work in 1st gear today! read this post, all done by lunchtime - you sir, are a superstar ! Thanks very much |
27th Nov 2020 1:52pm |
davidpalfreyman Member Since: 06 Oct 2010 Location: tanzania Posts: 67 |
Glad to hear that Dave's post worked for you too.
Can I ask, how did yours get stuck in first gear? Thanks, Dave (the other Dave who asked for help at the start of this thread) |
27th Nov 2020 5:30pm |
Yeah, I knocked it ‘out of gear’ without depressing the clutch..... 🤣
27th Nov 2020 5:48pm |
