Home > Td5 > Replacing injector seals
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, I think I need to replace them,
Is it a tricky job ? Or just a case of taking ya time ?
Any rips appreciated ,
Thanks in advance Thumbs Up
Post #512186 8th Mar 2016 8:11pm
dorsetsmith
Post #512192 8th Mar 2016 8:16pm
miker
Not particularly, just make sure you torque everything back up properly, put them back in the same holes, and set the rockers correctly
Post #512194 8th Mar 2016 8:18pm
Fatboy Slim
Wales
dorsetsmith wrote:
have a look link below
http://www.discovery2.co.uk/Injector%20Seals.html
Just to add to Nick's write up. You really don't need the timing pins or the injector puller
Post #512211 8th Mar 2016 8:54pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
I did this recently, Hayne's manual has the right torque information if you have one. Very simple job. Two things that could be helpful - I used a small heel bar to pop the injectors out perfect tool for the job really. Make sure you set the injectors down in order you took them out in. I put them on a piece of cardboard and wrote the numbers above.
Post #512231 8th Mar 2016 9:30pm
Daisy90
Brilliant write up and pics, thanks Thumbs Up
Looks "ok" so may order up some genuine bits and give it a go.
Watch this space Laughing
Post #512248 8th Mar 2016 10:01pm
Fatboy Slim
Wales
It's easy nothing difficult about it. Done hundreds.
Post #512258 8th Mar 2016 10:29pm
JWL
I generally do them one at a time, short term memory isn't what it used to be, so I don't get the injectors muddled up. No special tools needed, I use an allen key as a pry bar to carefully lift the injectors, just don't lever under the solonoid.
It is worth getting a new "rocker cover"gasket for when you put everything back together.
Post #512269 8th Mar 2016 10:43pm
L90DNY
Have a look at the injector wiring harness whilst your there, check the oil hasn't got in it, could cause issue down the line, if so would be worth replacing whilst you've got access.
Post #512425 9th Mar 2016 12:53pm
Johnb
United Kingdom 2004 Defender 90 Td5 CSW Belize Green
Do you need to replace the Rocker Shaft bolts or the adjusting screws ?
Post #514905 16th Mar 2016 12:59pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've done plenty, and never replaced old with new. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #514913 16th Mar 2016 1:21pm
Johnb
Thanks Ian have just completed mine took about 1 1/2 hours to do following the instructions at http://www.discovery2.co.uk/Injector%20Seals.html now runs as sweet as a nut Thumbs Up
Post #516483 21st Mar 2016 5:39pm
dorsetsmith
(Nick's write up) Did I clam to have written it no Evil or Very Mad
Post #516571 21st Mar 2016 8:25pm
Fatboy Slim
Wales
I didn't suggest you did chap. Just trying to save the OP a few quid
Post #516575 21st Mar 2016 8:36pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
And there was me thinking that the authors name IS Nick. It wasn't me!
Post #517802 25th Mar 2016 9:24pm
