Home > Td5 > Replacing injector seals |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
It is......Nick aka urban panzer on D2BC
25th Mar 2016 10:26pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Psssst.........I know. It wasn't me!
26th Mar 2016 4:14am |
kevinp Member Since: 30 Dec 2015 Location: west sussex Posts: 5 |
very interesting write up the only thing I would add is to stress the need to drain the fuel as if this is missed the fuel left in the head when the first injector is lifted will sit on the piston then when engine is started you end up with a bent con rod only added this as I know I like short cuts and I don't think im the only one
30th Mar 2016 5:59am |
I suck the bores out with a vacuum gun as you end up with brake cleaner etc down there as well from cleaning the seats
30th Mar 2016 6:04am |
