Home > Maintenance & Modifications > Wiring up spots
chalky
Wiring up spots
Right,
being a bit of a heavy handed bafoon when it comes round to the finer points of land rover ownership i am slightly dubious about wiring said units into my vehicles intricate wiring harness.
Oh and the fact that i will probably melt something ! set it on fire spike the ECU are also niggliing me a bit.
so, the question is do i do it Shocked
Or is this something that should be done by somebody who knows about vehicle wiring Idea DING !!
Is it spliced into the vehicles FULL beam or can it be dash mounted on a switch to come on regardless of the FULL beam being on or not.
I did see a while back some PIAA Spots that are to replace the WARN units on the 09 G4 vehicles.
These had a very trick switch that has a number 2 on that fits in the correct space on the dash.
Anyway,
as always any info will be much apreciated. DEFENDER XS CSW 08 TONGA GREEN
Post #5127 29th Nov 2008 7:30pm
mse
The switch is apparently avaliable as a part on its own, except i keep getting it as Front Fog Light on parts.
That said - it definately comes as part of the aux. wiring kit which is costly at �90 but includes everything needed to make it work.
If you get the genuine LR spotlights from a dealer at �270 - they also come with them. Mike
Post #5128 29th Nov 2008 7:41pm
chalky
mike
you are the font of all knowledge !
the spots look pretty dismal from the dealer but the wiring for them looks pretty substantial !
That said and following on from our conversation last night, how much can you purchase the Loom for Wink
And again following on from conversation EXPENSIVE as ever ! DEFENDER XS CSW 08 TONGA GREEN
Post #5130 29th Nov 2008 7:50pm
mse
I wouldnt go that far...
I would have to go to "That dealer"! Ill ask next time im there
Its bigger items the savings are great - except a car which is 12% on top of other offers
Here you are:
YUG000540LNF � Front Fog switch, Check price check for Aux 2
Wiring loom �98.64
Have a look at GTR the public side for the fitting guide i have it in pdf if you want me to email it, just pm me Mike
Post #5131 29th Nov 2008 7:57pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Yes that's the part (YUG000540LNF) I made up a harness and the switch cost me about ₤8 including postage to Australia. Over here it's not even a listed part Rolling Eyes
Pin outs are:
1 feed
2 illumination (take from pin 2 on another switch - lights up with other dash lights then)
4 ground
5 line out to lights (relay)
It takes a black connector, which I couldn't get and which is part of the wiring harness that LR supply. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #5135 29th Nov 2008 11:05pm
mse
So does that part come with the 2 and light symbol in it... as the pictures i cant tell! Mike
Post #5138 29th Nov 2008 11:16pm
dm_td5
The pins on the switch are all numbered, bit hard to read as they are down inside the switch (against the respective pins) from memory its 1-5 right to left, but double check.
Yes that part does have the 2 and light symbol.
Found the other thread on the forum: http://www.defender2.net/forum/topic552.html?highlight=switch
Dave's 101 posted up some links to pic's of the switch in this thread. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #5139 29th Nov 2008 11:48pm
mse
I wired a bank of those switches on my disco (they are the same as RR classic and d2 Wink ) both with genuine connectors and small crimped connectors - its not too hard as i recall.
thanks for the confirmation of switch facia type. Mike
Post #5140 30th Nov 2008 12:39am
PaulMc
I've posted some info on wiring YUG000540LNF in the Switch Fascia thread -
http://www.defender2.net/forum/topic552-15.html
Paul. Paul.
Post #6364 17th Jan 2009 12:12pm
Grockle
We had the LR driving lamps fitted before collection at good price, the '2' switch is in the kit. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6365 17th Jan 2009 12:50pm
mse
ive also i created a post a few weeks ago about fitting the switch http://www.defender2.net/forum/topic795.html Mike
Post #6368 17th Jan 2009 6:55pm
