![]() | Home > Maintenance & Modifications > OIL CHANGE |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Ive not serviced mine myself yet but it has been done.
I was told there is one filter and i understand it to be in/behind the black dome unit underneath with a plastic nut type thing on it - passenger side Mike |
Yep changed mine really easy just watch when you open the drain plug because the oil flows quickly
(if you get oil on anything wd40 is the best to remove it i.e drive) NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 ![]() ![]() |
If you're going to do this on a regular basis, well worth investing in one of these:
http://www.screwfix.com/prods/21663/Van-Ca...-Extractor - easier and far less messy. Good for lawnmowers and things too. |
Even better is this...http://shop.difflock.com/difflock-drainplu...537c8a6ed9 im not sure if they have one for the new defender yet, but its really easy (have one on all other LR products) Mike
Thats the ticket mse,excellent solution NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
They are good - drain oil, clean a little locktite on the thread and then fit and forget - ive extended the pipe so you go underneath when warm, remove the cap - screw in and it drains straight to the waste container...really no mess Do up, change filter (ice cream container) and your done. Mike |
Yep next on the list, Will save time and all the mess NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
The easy drain plug for the tdci is now on difflock and probably has been for a while. Does anyone happen to know if the torque setting for the new one should be the same as the standard drain plug? I think its 17 lb ft from memory for the standard
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
its pretty straight fwd to change the oil and if your from a S1 back ground it should be a walk in the park.
there is one filter, access it from under the vehicle, its on one side of the engine a tad higher than the sump located in a black platic dome which has a large platic nut on the end of it 32mm? or similar IIRC. undo the sump plug, drain the oil, preferably when its warm, removed the plastic dome, (filter will come out with it) use a plastic bag to contain it all (ie hand in bag, undo and wrap bag around as it undoes). Filter is held in by push fit on a central spindle, just pull it out, clean out the plastic bowl, fit new filter with new seal and refit. personally i dont bother pre filling the filter with oil. wait for engine oil to drain, refit sump plug and refill. IIRC engine takes 7L of oil. i do a change every 6k on mine. i prefer the sump plug out method as it allows a good flow of oil and would take any debris out with it over the suction methods, but i use the suction methods on vehicles where i do a high mileage ie 1k miles a week so oil changes are very regular. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Diff lock sump plug is the way forward for quick and clean oil changes
Been on for a while - refit torque was on the side when i got mine Mike |
Was just planning my early-life oil change (at about 1000 miles).
On the Workshop Manual it says:
Install a new drain plug? That's a bit extreme? Usually it's just a new crush washer (on my old TD5, and indeed most other cars/vehicles I have owned). Does anyone actually do this, or just clean and refit? NB - Don't want to do the difflock easy-drain until it's out of warranty... It also says re the plastic oil filter housing:
That also seems awful tight for a plastic (I assume?) oil filter housing? My Volvo one is only 9Nm I think... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 26th Sep 2011 8:20am. Edited 1 time in total |
you dont need a new drain plug.
but seconded re the diff lock drain plug. Not sure why you would wait until out of warranty. it makes oil changes a clean, easy and quick job. |
Yes exist for Puma also, installed mine one years ago............ Clean and quick solution!!!!!!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
And when you see the size of the new filter in comparison to what LR usually uses you will be amazed that a filter so small can actually clean oil for the duration of the service interval. 6,000 miles for me maximum. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
