Home > My Defender > Corris 110....
Page 22 of 48 <123 ... 212223 ... 464748>
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
If you have the day off what the hell are you doing up posting on here at 5.36am Rolling with laughter
Post #508350 26th Feb 2016 7:59am
mcma1
Was eating my porridge... I normally surface at 5 for some pre chaos exercise. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #508351 26th Feb 2016 8:03am
mcma1
Took off the grilles tonight, good time to clean and replace any worn screw plugs... I fitted the adventure front but it was too dark for pictures... A little more room behind the winch which I don't mind.
Will make a start on the over head player next I think, most of the kids stuff is always on a Memory stick so I need to have the USB connection available in the rear. Makes sense to put it in the cubby tray so printed a little surround and good to go.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Corris 110 SW
LS3 V8 build...
Post #508521 26th Feb 2016 7:56pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Love how you just print the bits needed, so want a 3D printer now
Very professional factory finish love this truck
Post #508528 26th Feb 2016 8:10pm
Avelingporter
I work designing Superyachts. Your attention to detail is right up there with the best. Much respect and admiration.
Douglas
Post #508568 26th Feb 2016 9:28pm
mcma1
Thanks Douglas. Thumbs Up
I can't wait to get it all back together and see all the ideas working... Andy
2014 Corris 110 SW
LS3 V8 build...
Post #508580 26th Feb 2016 9:59pm
leonski
Hi Andy,
Great work all round, I'm loving watching it all come together. The one negative as I have major envy on so many of your additions!
Looking forward to seeing the grill in place
I hope you don't mind me asking but can you tell me where you got it from, as I have been considering one for the 110.
Keep up the fine work.
Cheers,
Leon.
Post #508691 27th Feb 2016 12:30pm
SailingTom
Lovely job Andy
liked your 90, but this 110 is amazing!
Definitely the best vehicle on here, with some great work going into it.
Nice updates aswell.
10/10
Tom Very Happy
Post #508695 27th Feb 2016 12:41pm
mcma1
Thanks Guys!
Got the front end all back on, really very pleased.. The nasty flaking plate is gone, and I have a bit more clearance now between the winch and grille... It just all looks a better factory fit which is what I wanted.
I picked it all up from my local dealer who has been great help getting me all the bits and pieces.
2014 Corris 110 SW
LS3 V8 build...
Post #508697 27th Feb 2016 12:47pm
mcma1
Should be fitting the new rear subframe on Monday.... Thumbs Up
2014 Corris 110 SW
LS3 V8 build...
Post #508721 27th Feb 2016 2:17pm
JOW240725
Hi Andy, Seeing the sub frame and your umbrella just poked in the rear seats.... I wonder if there is room under the seat drawers to run a tube side to side to hold the umbrella? Just a thought
Post #508750 27th Feb 2016 4:49pm
mcma1
Post #508770 27th Feb 2016 6:24pm
ericvv
Post #508773 27th Feb 2016 6:29pm
ericvv
Andy, a question.
How did you go about replacing your cubby box lid? Did you pry loose the interior side panel lining and then take out the three or so staples holding the ribbon of the standard lid? And did you then restaple the ribbon with the FCX lid?
And how did you reattach the interior lining afterward? Glue?
Thanks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #508777 27th Feb 2016 6:43pm
JOW240725
I was thinking more a tube hidden in the sub frame, so you slide the umbrella out when the door is open. A touch of Rolls Royce with the umbrella hidden in the door Rolling with laughter
Ericvv - when I changed my cubby lid for an FCX one I just slide a screw driver downwards between the ribbon and box and prized out the staples. Fitted new lid, pushed ribbon back between lining and cubby, I secured the ribbon with a screw/D clasp (to hang keys on) which also held lining back in place.
Post #508798 27th Feb 2016 7:23pm
