Home > Puma (Tdci) > Puma oil spec?
Page 3 of 5 <12345>
mse
Ive said before - it worries me with these defender's oil specs.
I dont believe the dealers fully follow them all (although they have more of a chance of doing it) so what chance does most indep. garages have...
I know the indep guys are great and im not knocking that - its just with many different specs and possibly less time to research etc - i bet you they put in the wrong spec more than the right spec (especially if you go to an none LR one were its just listed as a 5/30!!) Mike
Post #50824 3rd Jan 2011 10:20am
MK
Education is needed all over, You shuold take the lubrizol webpage or this one, I`m sure you can find in English
http://www.motul-lubricantes.com/eftm/defi...iviano.pdf Puma 110" SW
Post #50825 3rd Jan 2011 10:30am
Naks
While LR specifies ACEA A5/B5 5w30 oil for the Puma, it is by no means the best oil for the engine. This will depends on where you are: climatic conditions, quality of diesel, etc.
For example, in SA we have a much warmer climate than EU & sh*t diesel, so really in SA we should be using an API CH-4/CI-4 or ACEA E5/6/7 fully-synthetic oil, viscosity 5w40.
Post #50834 3rd Jan 2011 12:36pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
I threw out that Ford oil after 3000km and never went back to it.The loose spanners in the motor have gone and now have a oil to protect my engine and not fuel cosumption. Puma 110 SW
90 V8 SOFT TOP
Post #50858 3rd Jan 2011 4:26pm
Naks
What oil are you using if I may ask?
Post #50859 3rd Jan 2011 4:32pm
MK
I`m not sure, but the oil pump must be designed to deal with the viscosity given by a XXW-30 oil. Danielle ( Whistle ) should jump in again. Puma 110" SW
Post #50862 3rd Jan 2011 4:37pm
LESVOSD110
5w-50 A3/B3/B4 synthetic and changed every 6000km.It handles our heat and no cold start problems. Puma 110 SW
90 V8 SOFT TOP
Post #50864 3rd Jan 2011 4:40pm
dgardel
Italy
READ CAREFULLY!!!
high HTHS OIL is ALWAYS BETTER than a low HTHS oil!!!
But if I tell to the forum this and someone will have problems with the engine (not related to the oil)? May be LR look for the reason and invalidate the warranty?
SO, I do not tell nothing to the forum, understand!!!!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50877 3rd Jan 2011 5:37pm
Lorryman100
Why does this answer remind me of the epic film "The Godfather" Whistle Whistle
Post #50878 3rd Jan 2011 6:00pm
dgardel
Italy
mhmmmmmm you are wrong......
Italiani siamo
IID Pro MV License
Post #50883 3rd Jan 2011 6:25pm
Naks
You mean a 5w40/50 is better than 5w30?
I fully agree, it looks like LR only specified the oil that would be ideal for EU, NOT the rest of the world.
I have a friend in SA who has switched to Shell Rimula HX7 and says the landy runs much more smoothly. He buys the oil and force the dealer to use this when doing the service.
Post #50886 3rd Jan 2011 6:38pm
dgardel
Italy
viscosity is a different characteristic than HTHS.
for hot climate is better a 5W50 or a 10W60 than a 5W30 and all of these oils can have low or high HTHS.
a good HTHS is better for the shear strength
For educational purpose look here Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50893 3rd Jan 2011 7:03pm
Naks
Can you please specify the API classification and brand? Wink
Post #50894 3rd Jan 2011 7:07pm
LESVOSD110
Same happened with VW and there 0w30 longlife.Many top end failures and oil cosumption.They changed to there 5w-30 but still not good in hot climate like ours. Puma 110 SW
90 V8 SOFT TOP
Post #50895 3rd Jan 2011 7:07pm
dgardel
Italy
Look here: http://www.bobistheoilguy.com/forums/ubbth...amp;page=1 and related
Whereas main bearing wear increased with the viscosity below 2.2 HTHS, the con-rod bearing showed virtually no wear at the lowest tested 1.8 oil
same results on my 1998-2002 tests done in SBK 4 stroke engine and offshore racing boat engine..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50896 3rd Jan 2011 7:09pm
Page 3 of 5 <12345>
