Home > My Defender > Corris 110.... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2900 |
Yes have an alpine 10.2" screen due any day, will need to get a plinth made up for it and when the headlining is off I am adding the sound proofing Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
21st Feb 2016 11:26pm |
When I soundproofed and closed cell foamed my roof it made a great difference. Well worth the effort Ray
22nd Feb 2016 12:31am |
Rear electric window mod tested with success!, total cost for this will be £45 for both doors
Sorry for the rubbish video but with out it i could bluffing ..... Door card back on with no issues, will just need to print off a blanking cap but my doorcard are getting trimmed so wont be an issue. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
22nd Feb 2016 9:09pm |
Yes, you could switch them from anywhere you like! Andy
22nd Feb 2016 9:40pm |
£45 for both doors. I'm in was it mk1 disco regulators? I've been busy with new driveway gates so haven't ordered any to see if they'll fit. Ray
22nd Feb 2016 10:09pm |
Not sure, my mate had them sitting in his workshop when I was over today about other bits... So a bit off luck. Going to lick up a new rear regulator tomorrow and will then make up the final fitting. Andy
22nd Feb 2016 10:16pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 597 |
Great work, think we would all like a link to parts and a tutorial.
Also think the above comment meant having switches in the rear and also up front for the driver to override. Still curious as to what you are doing with the three switch set in the back? |
22nd Feb 2016 10:17pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3758 |
Yes,
I would want to operate them from the front (like most 4 seater cars...) and also the kids in the back could use them. so when I jump in without the kids and typically they are not quite shut, I can shut them Thanks, probably didn't explain correctly |
22nd Feb 2016 10:19pm |
One thing is they won't fit behind the panel like the front so they have to go on the outside, I will draw it up and offer the parts needed but it's one tiny piece that's needs to be machined up. Andy
22nd Feb 2016 10:21pm |
Can you clarify that, what wont fit, what panel, a bit machined in addition to one of the kits online?
I take it to mean the door card will not fit back on with the mechanism in place? |
22nd Feb 2016 10:34pm |
A couple of pictures but simple simple...take the motor apart and remove geared shaft... This leaves you with a rounded slot... The winder shaft then gets replaced with a new one to the new profile a also shorter. Then you just place the motor over the new shaft fix it on with bolts and job done... Don't rush out and try it, I will machine up the new winding shafts this week and then you will just need to grab motors... Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
22nd Feb 2016 10:35pm |
Makes perfect sense. Please put me down for a set of the modded bits when done.
22nd Feb 2016 10:50pm |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 |
Good work there! I know I keep pestering about your 3D scan, but pretty please haha! I promise I won't copy your seatbox
I like the rear window mods. Plenty of potential for printing up an extended door handle with a slightly angled pod for the button perhaps. North Cumbria Search and Rescue - Team Leader |
23rd Feb 2016 2:48am |
Lol, still need to add more data for you!
Pretty sure the switch can be fitted into the door card... My surrounds will finish this morning and I can check then. I might make up a kit that has the motor parts needed and surround Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
23rd Feb 2016 7:25am |
