Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
Click image to enlarge In here (one marked ".99") http://s242.beta.photobucket.com/user/appa...3.mp4.html Please ignore the fact I sound like a tosser. |
13th Dec 2012 6:25pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I've not got a puma manual in front of me at the moment,
But, you'll need to pull the rear washer switch out of the dash. get a voltmeter and find the 12v which becomes live when you push the button. You'll then need to pull the washer switch out of the dash, and meter the 12v feed to the motor when you press the button. So, once you've found that, you'll need to connect both of these together. however i'd have thought that a diode would be needed inbetween both switches, otherwise you'll get feedback when you turn the rear wiper on... the washer will run all the time too! |
22nd Jul 2013 3:24pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Thanks DJ. Just found this after a bit of a root about and it shows a method of wiring the washers in. Click image to enlarge All credits to Barny Rubble |
22nd Jul 2013 3:35pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
Old post I know, just bought a 99 relay. Just to clarify - so after I've set the delay and it's wiping with that delay, if I then turn it off and then back on again (in less than 6 sec) will it come back using the previous delay, or the new delay between single wipes? And also does just popping the stalk down the first time (no delay set yet) put it on the normal delay as usual? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
5th Aug 2013 9:18pm |
Click image to enlarge Front and back now modded |
18th Aug 2013 1:32pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Would this work on the rear wiper? I miss the programming wiper speed my lady cat had this mod will certainly happen
18th Aug 2013 3:08pm |
It's seems my question has been answered already. Would you happen to have a diagram for wiring or is it simply wrote in before the original relay?
18th Aug 2013 3:11pm |
Diagram above
18th Aug 2013 3:15pm |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
Sorry for dragging up an old thread.
I did the "99 relay mod" today to my 08 TDCi. Click image to enlarge Works great, can program it and all functions work etc. However, I had to remove it and replace with the original red relay, because once the engine was running the battery light on the gauge binnacle stays on and doesn't go out. Any ideas on why this would be?! Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
6th Jul 2014 10:04pm |
Organic Member Since: 05 Oct 2015 Location: Shropshire Posts: 21 |
Silly question, sorry, but should you disconnect the battery to swap the relay?
22nd Feb 2016 12:15pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
No need to disconnect battery to fit the relay, might be best to have the ignition off though
22nd Feb 2016 1:04pm |
Cheers Eddie
22nd Feb 2016 1:32pm |
LandieG Member Since: 13 Mar 2013 Location: nr Caerphilly Posts: 91 |
one of the most useful mod's I've done........... especially this year although mostly my wipers have been on continuous rather than using this groovy feature
lol G |
23rd Feb 2016 11:37pm |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 |
A great mod thats cheap (unlike so many of my other plans) and simple to do. Only down point was its the first time I've had the instrument housing off and turns out the previous owner has snapped off the RHS lower fixing leg. So its one job ticked off and one added 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
3rd Mar 2016 7:33pm |
