Home > Technical > SVX Grille fitting - help please
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Hi all,
I'm considering taking the plunge and buying an SVX grill set however I have a modified a bar on the front of my defender which sits a bit closer to my standard non-aircon grill.
Would someone with an SVX grille be so kind as to measure how much it protrudes past the leading edge of the bonnet to see if I can get it to fit?
Thanks in advance! Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #500838 5th Feb 2016 12:52pm
K9F
This may help. Use Dgardel as point of contact.
http://www.defender2.net/forum/topic15159....=svx+grill If you go through life with your head in the sand....all people will see is an ar5e!!
Post #500841 5th Feb 2016 12:57pm
X4SKP
Hello TDCi Guy
Here's the KBX 'projection' figure...80 mm
Not what your looking for exactly but while talking to an Urban Truck owner with a SVX Grill
I noticed that they are very similar...wait until you get someone to confirm how close.
When you say 'modified a bar' any pictures... Question
I'm progressing a 'mounting bar' currently for a pair of additional driving lights and things do get
tight around this area when you get into the geometry of things.
Mine has AC fitted.
Good Luck SKIP
Post #500863 5th Feb 2016 1:45pm
TDCi Guy
Thanks for the help so far guys. I can't see it sticking out much more than an air con grill with a kbx on but will await confirmation.
When I say modified a bar all I mean is that I chopped some of the plastic out of the back of a plastic a bar so that it would fit closer to the grill. You could park a bus in the gap between grill and a bar on a non-aircon truck.
I didn't have any of the original mounting brackets so I was making those up from scratch anyway. Worst case scenario I could always make up a spacer to push the a bar back out again to give room for the grill. Tom
@tditomprice
Post #501147 6th Feb 2016 8:48am
dgardel
Italy
Re: SVX Grille fitting - help please
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #501269 6th Feb 2016 1:14pm
