Home > Technical > SVX Grille fitting - help please |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
Hi all,
I'm considering taking the plunge and buying an SVX grill set however I have a modified a bar on the front of my defender which sits a bit closer to my standard non-aircon grill. Would someone with an SVX grille be so kind as to measure how much it protrudes past the leading edge of the bonnet to see if I can get it to fit? Thanks in advance! Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
5th Feb 2016 12:52pm |
This may help. Use Dgardel as point of contact.
http://www.defender2.net/forum/topic15159....=svx+grill If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
5th Feb 2016 12:57pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello TDCi Guy
Here's the KBX 'projection' figure...80 mm Not what your looking for exactly but while talking to an Urban Truck owner with a SVX Grill I noticed that they are very similar...wait until you get someone to confirm how close. When you say 'modified a bar' any pictures... I'm progressing a 'mounting bar' currently for a pair of additional driving lights and things do get tight around this area when you get into the geometry of things. Mine has AC fitted. Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
5th Feb 2016 1:45pm |
Thanks for the help so far guys. I can't see it sticking out much more than an air con grill with a kbx on but will await confirmation.
When I say modified a bar all I mean is that I chopped some of the plastic out of the back of a plastic a bar so that it would fit closer to the grill. You could park a bus in the gap between grill and a bar on a non-aircon truck. I didn't have any of the original mounting brackets so I was making those up from scratch anyway. Worst case scenario I could always make up a spacer to push the a bar back out again to give room for the grill. Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
6th Feb 2016 8:48am |
Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Feb 2016 1:14pm |
