![]() | Home > Puma (Tdci) > Engine Management Light |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Sometimes the MIL light resets after 3 driving cycles. If not you will need to have the fault code recovered from the ecu to tell you what caused the engine light to come on. Do you know anyone with a OBDII fault code reader? As your landy is out of warranty maybe a scangaugeII, nanocom evolution, blackbox FCR or hawkeye would be a good purchase as they all read and clear faults stored in the ecu. Dgardel has on here a link to download the faultcodes
http://www.defender2.net/forum/topic3432.h...ault+codes I have the scangaugeII and santa is bringing me the nanocom unit. The scangauge is mounted in the car permanently where as the nanocom unit is for more specialised use. http://www.scangauge2.co.uk/ http://web.nanocom.it/default_i.cfm ![]() Click image to enlarge ![]() |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 ![]() ![]() |
Try an Italian tune. Pimped black '07 Puma
Equally Pimped Black Pick up Truck Rollin deep |
Willie Member Since: 08 Oct 2009 Location: Stockton Posts: 48 ![]() ![]() ![]() |
It would seem Santa brought me a present today and turned out the EML as Lorryman100 suggested potentially saving me £300. Should I still get the LR dealer to check it out or should I just put it down to the very cold weather.
Willie Defender Virgin |
the dealer will charge you for plugging in the diagnostic tool to read the code. The cost depend's on the dealers hourly rate. I would recommend as your out of warranty the scangauge 2 as you can read and reset fault's potentially paying for itself the first time it is used to check and reset the fault!
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Fully agree with Lorryman100. Excellent piece of kit. Has many other uses as well. Calculating MPG, once set up, Outside Air Temp, when on the move, Battery Voltage, Water Temp and many others. Worth every penny, and as Lorryman100 says, just 1 trip to the dealers to run a diagnostic pays for itself.
Just ordered a scangauge 2 has my MIL light as came on .....still running fine though ? see what the scangauge finds when it turns up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Just received the scangauge 2 plugged it in and cleared the codes....Mil light has gone out
![]() P1103 Mass air flow sensor in range but higher than expected. ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
EGR problem that sounds like. Have you fitted a blanking plate? If not i would say the valve is stuck. Pete. |
Yes had the blank on for a good six months i think its the 18m one.....i've run it all day and the light has stayed off fingers crossed NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Well now you can reset it and know what it is then its not a problem!
![]() Just keep a eye on it but i would say its the EGR blank that caused it. Pete. |
Thanks Pete, I'll keep a eye on it see if it happens again...could it be that the blank hole has got sutted up ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Fekete, took my 12mm blank out today after a few thousand miles of use and replaced with original gasket as I have the BAS EGR Shut map update, suffice to say there was no sign of the hole being sooted up, could it be the sensor itself or more likely the EGR playing up, mine always seems to run smoother after a proper long run of a few hundred miles?
Hi BIGFOG Thanks for that it was just a thought.....the light went on after a continues 250 mile run ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Hmm, nowt stranger than an EGR - damn the things and damn the silly brain of a Puma for being so damn fussy!!
