Home > Tdi > Is this right/normal?? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
No it should sit in the middle. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Jan 2016 10:00pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1172 |
Thanks Martin.
So the fact it didn't go into the red isn't necessarily a good thing? My confidence has been writing cheques that my abilities can't cash for years. |
18th Jan 2016 10:01pm |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Have you got an electric fan fitted replacing the viscous fan? If so the temp gauge can rise almost to the red then the electric fan kicks in. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
19th Jan 2016 10:53am |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
i believe there are different senders/gauges and that you need a matched pair 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
19th Jan 2016 12:28pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2645 |
If it's a vehicle that's been converted with a Disco 200Tdi then it could be mismatched sender as above.
19th Jan 2016 4:03pm |
I know it's had a different 200tdi fitted
Best get the engine number checked out to see what I have & therefor need Thanks lads My confidence has been writing cheques that my abilities can't cash for years. |
19th Jan 2016 10:19pm |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Any solution? I am very interested as I am having temp. problems as well?
Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
25th Jan 2016 5:28pm |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 827 |
Does the guage go up when lights and heater turned on? If yes it's an earth issue.
If it sits high but won't go into red then could be as mentioned the gauge and sender don't match. My 200 sat just off the red never over heated ran perfect for 10's ooo's officials miles even towing. I replaced everything rad ( it was rotten) hoses, head ( cracked ) fan , sender , guage and ended up just living With it. Have fun be happy |
25th Jan 2016 5:38pm |
I have changed everything…..even thermostat to oil cooler….
The temp stays in center until going above 50 mph…then it goes to end of the white… Wiring is ok.. regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
25th Jan 2016 5:52pm |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 |
I have had same problem for last 5 years after a complete rebuild of standard 200tdi.... have just learnt to live with it ....done 20,000miles with no issues ...changed thermostat, pump etc ...never goes in red but very close. am running the 88 deg C thermo so heater is toasty !
25th Jan 2016 8:57pm |
Hi Tompoole,
No it sits still when the engine is started then slowly climbs up to that point in the picture. I guess it's a mismatched gauge & sender as you suggest. When I get into work I will get the engine number checked out to see what I have and change what's needed. Or, knowing me, I will just live with it!! G My confidence has been writing cheques that my abilities can't cash for years. |
25th Jan 2016 9:17pm |
PRC8593 200tdi defender temp sender
PRC 8001 200tdi disco temp sender orange PRC 9917 200tdi disco temp sender green |
25th Jan 2016 9:50pm |
Thanks Dorsetsmith My confidence has been writing cheques that my abilities can't cash for years.
27th Jan 2016 2:25am |
