Home > Tdi > Is this right/normal??
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Have owned my 200tdi for over a year now and the poor thing has only just had the temp gauge fixed.
On my way home tonight (first time I have driven it with it working) it went to the top of the white bit ...
Is this where it should sit for normal operating temp??
G
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  My confidence has been writing cheques that my abilities can't cash for years.
Post #493895 18th Jan 2016 9:50pm
Martin
Site Admin
No it should sit in the middle.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #493901 18th Jan 2016 10:00pm
Enid_Puceflange
Thanks Martin.
So the fact it didn't go into the red isn't necessarily a good thing? My confidence has been writing cheques that my abilities can't cash for years.
Post #493903 18th Jan 2016 10:01pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Have you got an electric fan fitted replacing the viscous fan? If so the temp gauge can rise almost to the red then the electric fan kicks in. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #494016 19th Jan 2016 10:53am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
i believe there are different senders/gauges and that you need a matched pair 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #494032 19th Jan 2016 12:28pm
Retroanaconda
If it's a vehicle that's been converted with a Disco 200Tdi then it could be mismatched sender as above.
Post #494096 19th Jan 2016 4:03pm
Enid_Puceflange
I know it's had a different 200tdi fitted
Best get the engine number checked out to see what I have & therefor need Thumbs Up
Thanks lads My confidence has been writing cheques that my abilities can't cash for years.
Post #494234 19th Jan 2016 10:19pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Any solution? I am very interested as I am having temp. problems as well?
Regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #496262 25th Jan 2016 5:28pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Does the guage go up when lights and heater turned on? If yes it's an earth issue.
If it sits high but won't go into red then could be as mentioned the gauge and sender don't match.
My 200 sat just off the red never over heated ran perfect for 10's ooo's officials miles even towing.
I replaced everything rad ( it was rotten) hoses, head ( cracked ) fan , sender , guage and ended up just living
With it. Have fun be happy
Post #496266 25th Jan 2016 5:38pm
CRJ
I have changed everything…..even thermostat to oil cooler….
The temp stays in center until going above 50 mph…then it goes to end of the white…
Wiring is ok..
regards
Puma 130 - 08- sold
110 CC 2003
Post #496273 25th Jan 2016 5:52pm
Bumpymike
United Kingdom 1992 Defender 90 200 Tdi SW Bronze Green
I have had same problem for last 5 years after a complete rebuild of standard 200tdi.... have just learnt to live with it ....done 20,000miles with no issues ...changed thermostat, pump etc ...never goes in red but very close. am running the 88 deg C thermo so heater is toasty !
Post #496362 25th Jan 2016 8:57pm
Enid_Puceflange
Hi Tompoole,
No it sits still when the engine is started then slowly climbs up to that point in the picture.
I guess it's a mismatched gauge & sender as you suggest.
When I get into work I will get the engine number checked out to see what I have and change what's needed.
Or, knowing me, I will just live with it!! Rolling Eyes
G My confidence has been writing cheques that my abilities can't cash for years.
Post #496374 25th Jan 2016 9:17pm
dorsetsmith
PRC8593 200tdi defender temp sender
PRC 8001 200tdi disco temp sender orange
PRC 9917 200tdi disco temp sender green
Post #496391 25th Jan 2016 9:50pm
Enid_Puceflange
Thanks Dorsetsmith My confidence has been writing cheques that my abilities can't cash for years.
Post #496906 27th Jan 2016 2:25am
