fitted a 12v socket in the rear of the 110 next to the speaker, nice easy job.
remember purple wire is +ve |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Christmas shopping - EXTREME!!
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
Spent about three hours with the jetwash blasting all the crap off the chassis and washing it, only to realise I'm on the farm tomorrow so it was a wasted effort.
Not sure where Funrovers spot is, I can't quite place it, but I've always found the parking spot at Yeadon Cemetery a good spot. If it's any better than the cemetery I'd quite like to know too ![]() ![]() |
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 ![]() ![]() ![]() |
Hi guys, it was here: http://tinyurl.com/leedsbradford
From what I can remember, the view used to be a lot better, those two large hangers now obscure it somewhat. It's right off Bayton Lane, take your Landy, you'll need and some yobbos have been tearing the place up with their offroaders. There are police notices about not using the area to off road - but as long as I remember plane spotters have gone here with their radios and such Here's the kind of views you can expect: ![]() Click image to enlarge Editor of FunRover - One blog. Read it! Land Rover rebuild video series here: |
Nice one
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Cheers funrover, might go there tomorrow.
discoch1 Member Since: 06 Dec 2009 Location: 3722 Scharnachtal Posts: 38 ![]() ![]() ![]() |
Made myself a top hat to stop the snow and water getting in to the air intake for the cabin heating. It works a treat.
Then I made a rad muff as well! Just wish I could work out how to attach a picture so that you can see it? [/img] Forgot to write: Corr It's yonks since I was up on that hill above the airport! Last edited by discoch1 on 14th Dec 2010 3:57pm. Edited 1 time in total |
bjartin Member Since: 17 Nov 2009 Location: Hedmark, Matrand Posts: 108 ![]() ![]() |
ASTA (my Puma's name) was completely white with salt, washed it with a sponge and warm soapy water, rinsed afterwards with cold water from a garden hose: the result was a Defender with an armor of ice.
The temperature was minus 6.4 degrees Celsius. Puma 90 MY 2010 (sold 2017) Defender 110 MY 2001 http://www.youtube.com/bjartin |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Finally got around to fitting the scangauge
![]() Click image to enlarge didn't like it there so moved sat nav over a bit and think it looks better here ![]() Click image to enlarge had an old phone mount lying in the garage so after a little cutting and moulding fitted supplied velcro fasteners and attached scangauge and was delighted to see how securely it fitted to the window mount. Went for a drive over bumpy roads and through potholes, scangauge didn't move, vibrate or fall off. Result ![]() ![]() Click image to enlarge |
casher Member Since: 17 Sep 2010 Location: Glos Posts: 58 ![]() ![]() ![]() |
what are those scangauges like, ive just been googling them, but would rather hear it from the horses mouth, as thats one thing i do miss is know my mpg all the time
Does exactly what it says on the tin
Posted a package. Admired it's shinyness.
Fitted parking sensors onto the Ice Defender, same model as dgardel's - they work a treat.
Had the doorlocks and ignition barrel swapped out under warranty! Ignition barrel was internally falling to pieces! Bill would have been a few pence short of £312!!! No more wrestling with the key! Even cleaned it for me too! Refused to road test it due to sticky out wheels, never mind it kept an 'oily rag' from driving it!!! If you go through life with your head in the sand....all people will see is an ar5e!!
