Home > Maintenance & Modifications > Judder on take off and reverse |
Toby60 Member Since: 06 Dec 2014 Location: Cheshire Posts: 28 |
I can't see it being anything to do with the transfer box and I would not be changing that on a trial and error basis. When you had the clutch done did you have a new flywheel? ------------------------------------------------
2002 TD5 90 HT County |
15th Dec 2015 10:07pm |
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 |
No the flywheel was not changed with the clutch.
Since day one I thought if left like it was coming from a diff - but front and rear have been checked and are ok. I have been planning on changing the transfer box to a disco one with better ratios - so it is a good excuse |
15th Dec 2015 10:26pm |
I had the transfer box in my 90 converted to the Disco 1.2 ratio a couple of months ago and I would certainly recommend that. It drives a lot better at speed.
I reckon the judder problem maybe due to your flywheel but it's best to ask someone with more knowledge of these things. ------------------------------------------------ 2002 TD5 90 HT County |
15th Dec 2015 10:33pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17539 |
The DMF is the most common cause of clutch judder on a TD5 by far. It is a false economy not to replace the DMF if replacing a clutch, since in normal use the clutch will outlive the flywheel.
It is also possible that you'll get judder if the engine and gearbox mounting rubbers are going soft, or if the suspension bushes are worn allowing too much movement in the (usually, rear) axle mountings. The DMF is the worst feature of the TD5 Defender or Disco, and its appalling performance is the reason that LR reverted to a conventional flywheel and clutch on the TDCi. It is regrettable that they made arguably a worse job of the latter even than the former! |
16th Dec 2015 8:35am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
I was going to mention bushes too, especially rear shock / damper bushes.
When moving of weight is obviously shifted to the rear and poor bushes move around a lot giving a feeling of the being drivetrain issues. I'd also agree that it's usually the rear too. |
16th Dec 2015 12:14pm |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 |
Sounds like clutch judder . You'll more than likely have some hi spots on the flywheel
16th Dec 2015 7:50pm |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 |
Had it on my Td5 Disco 2 and have it now on my Td5 90.
The disco I bought at 120k miles and sold at 180k miles. As far as I know the clutch hadn't been replaced. Judder never materialised into anything more. |
21st Dec 2015 3:17pm |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 260 |
I've just taken my engine out to do some bits and bobs, and whilst there fitted a new clutch and DMF.
Clutch looked almost unworn and barely any play in DMF at 142k miles! However it had started juddering the last year or so, and a new clutch has cured that. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
21st Dec 2015 3:53pm |
