Home > Maintenance & Modifications > Judder on take off and reverse
Paintedpilgrim
United Kingdom 1998 Defender 110 300 Tdi CSW Epsom Green
Hi, I've got a 2002 110 ex untility defender, There is really excessive judder on take off and when reversing when releasing the clutch and everything is taking up drive. I'm no mechanic but it feels like the props juddering. I've owned lots of discovery but this is my first defender, I know they are not silky smooth rides but this is a lot worse than any of the discos I've had. I was wondering maybe being utility and spending a lot of its life off road if certain parts were worn out maybe, where's the best place to start looking as its bugging me now! Cheers
Post #482171 14th Dec 2015 6:55pm
Worn prop UJ's? When was the clutch last changed?
Post #482174 14th Dec 2015 6:59pm
DMF and/or clutch, a very common occurrence.
Post #482176 14th Dec 2015 7:01pm
Paintedpilgrim
Not sure on the clutch, feels fine other that this, how would I check the uj for wear? What is the dmf please?
Post #482181 14th Dec 2015 7:04pm
DMF = Dual Mass Flywheel.
No DMF on mine as it's a Puma, however I had similar problems and it was the clutch.
They told me the clutch was worn but not really badly but the friction plate was pitted.
That might explain the juddering which I had too.
Post #482189 14th Dec 2015 7:30pm
Paintedpilgrim
Ah I see, sounds expensive to me! How could I tell if it is the clutch or dmf?
Post #482198 14th Dec 2015 7:56pm
That's the problem, you can't unless it's apart.
And yes, it is expensive!
It got worse for me until one day it suddenly and unexpectedly got so bad it was slipping all the time in every gear. You'd change, bring up the clutch and no drive until about 2 secs later. I just got home and then needed recovery to dealer.
Other members here are more experienced on the mechanics and spannering side than me.
It can't be prop balancing as that'd be during drive not moving off.
UJ's would need to be checked for rotational play in them, I'm not sure how much play they should have as standard.
They do have tolerances of a certain amount of play in them from new.
Post #482215 14th Dec 2015 8:23pm
rallysteve
Is it better after everything has warmed up a bit after a few miles?
When does it do it, as soon as the clutch starts to bit or just before you have finished raising the pedal?
Post #482249 14th Dec 2015 9:42pm
Paintedpilgrim
Yeah it is a bit better once warmed up and it does it just as the clutch bites
Post #482252 14th Dec 2015 9:46pm
Paintedpilgrim
It doesn't matter how gently you disengage the clutch it happens, but it's fine once your going along although you do have to lift the clutch slowly after a gear change
Post #482254 14th Dec 2015 9:48pm
Toby60
United Kingdom 2002 Defender 90 Td5 HT Coniston Green
I have a 2002 TD5 90 that has some clutch judder when the vehicle is first used and once warmed up it goes away. It occurs from when the clutch bites to the fully released position. The vehicle has done 123,000 miles and is on its original clutch. I put it down to either dampness or a small amount of oil on the clutch plate. Although due to the mileage, the clutch could be on its way out but it does not slip at any time.
Is the judder something I should be concerned about? ------------------------------------------------
2002 TD5 90 HT County
Post #482270 14th Dec 2015 10:21pm
Jeez, 123k on original clutch. Puma one's must be made of cheese!
Mine was changed at 44k. Rolling Eyes
Post #482302 14th Dec 2015 11:41pm
Paintedpilgrim
Mines done 143k but I didn't get any history with it so have no idea if the clutch has been done
Post #482353 15th Dec 2015 7:38am
landy andy
Take props off and throughly check all the UJ's and slides, but it does sound more like the DMF to me.
Sorry
Andy
Post #482386 15th Dec 2015 9:46am
Stacey007
How much is a clutch on a puma?
Post #482413 15th Dec 2015 11:29am
