Home > Puma (Tdci) > Engine block preheater
Page 2 of 3 <123>
dgardel
Italy
dm_td5 wrote:
dgardel: How in hell do you keep the Defender THAT clean? Do you drive into a canal every week to wash it?
Hemmm
photos taken from www.entreq.de.
It isn't my car............... Whistle Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #48119 10th Dec 2010 2:19pm
BigMike
dg, do you have these parts in your kit? Apparently you need them for a landrover installation. I know that you know what you're doing, but this has just been highlighted to me that its extra from the kit itself and needs buying.
Hose - Part/No 33894A
T Piece for fuel connection - Part/No 66944A
Post #48131 10th Dec 2010 5:36pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
dgardel wrote:
Hemmm
Ahhhhhhhhh! Thumbs Up 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #48157 10th Dec 2010 8:32pm
dgardel
Italy
I use the "T" for the fuel line and the thermostatic valve 19873A:
because have a better efficiency (no losses) when the heater is switched off than the "in-line solution (my first idea):
The connections for the Puma is:
Here same draws
On the Defender, I chosen to install the heater using the e-ntreq solution
Last, 7 days Timer also:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #48167 11th Dec 2010 12:48am
dgardel
Italy
You need the standard Webasto THERMO TOP C general installation kit AND the back valve (must buy separately, ca 30,00€).
In total my costs was (installation by me!!!)
Webasto main unit (new) 180,00€ (by friend)
Standard installation kit (complete o wiring harness, water pipes, exhaust and more) 135,00€ (ebay)
7 Day Timer 85,00€ (eBay)
entreq plate and back valve 180,00€
Total = 580,00€, NOT BAD!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #48168 11th Dec 2010 12:56am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
dgardel - is the non return valve a Webasto product or Entreq?
Post #48239 11th Dec 2010 11:25pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Teeing into the fuel line won't work as the solenoid pump will not have enough suction to pull the fuel up the landrover fuel pipe. Webasto and Eberspacher fuel pumps need to use the supplied suction pipe which is approx 2mm Id bore. Been there done that and learnt the hard way Rolling with laughter easiest option is a separate tank it only needs to be a few litres as they use next to no fuel.
Post #48241 11th Dec 2010 11:42pm
dgardel
Italy
Webasto P/N 12780A Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #48246 12th Dec 2010 12:45am
dgardel
Italy
Thumbs Up
Is an option on mine mind............thinking about the place on the truck Thumbs Up
Otherwise I need to remove the fuel tank for fit the Webasto suction pipe.......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #48247 12th Dec 2010 12:48am
Finnskogingen
Norway 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Webasto comes as standard equipment here in Norway. Works great! I have a video on youtube of my puma with webasto heather. http://www.youtube.com/watch?v=e9D5btyUS2o
Post #48248 12th Dec 2010 1:17am
dgardel
Italy
Could you make same photos especially for the burner position (seems on the right, on the internal part of the Defender frame) and where the webasto water pipes are connected (closer the cabin heater valve? [closer to the brake servo]).
And a photos where the small pipes (the pipe that came from the car radiator) is connected to the engine expansion tank.
Thank you
Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #48249 12th Dec 2010 1:29am
BigMike
Your installation is pretty cool I must say - but why didn't you just tap into the main fuel tank?
Post #48263 12th Dec 2010 11:04am
Sonic3d
Didn't want to drill the main tank and possibly cause problems when in the middle of nowhere Thumbs Up And it's easier for me to just knock up an alloy tank than drop the main tank to fit the Eberspacher pickup pipe.
Post #48275 12th Dec 2010 3:50pm
BigMike
yeah that's a worry of mine too. Is the 2 mil pipe ok to cope with a feed from an auxilliary tank? I know your tank is in the load bay ie outside the vehicle, do you (or anyone else for that matter) have any ideas of where to put it in a 90 if the heater unit is under the bonnet? I dont want to put mine under the vehicle, too vulnerable for what I do.
Post #48278 12th Dec 2010 3:59pm
Sonic3d
The 2mm pipe is fine, we tried it with 6mm and it wouldn't work. If I was going to fit one to a 90 I would make a tank to fit under the drivers wing top and hinge the plastic vent on top for the filler.
Post #48283 12th Dec 2010 5:46pm
Page 2 of 3 <123>
