Home > Puma (Tdci) > Engine block preheater |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
cheers - are we talking epersbacher though or webasto?
12th Dec 2010 6:17pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Both use the same type of pump |
12th Dec 2010 6:34pm |
that's interesting, cheers Sonic. Can you make me a sonic special fuel box
12th Dec 2010 6:39pm |
Far too busy with work and bolting bits to the Disco Give Allisport a ring about making a wing top tank
12th Dec 2010 6:51pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
If i was putting a tank on the 90 i wouldnt put it in the engine bay - i would put it under the drive passenger rear wing right behind the door.
With some simple tap filler arrangement. Mike |
13th Dec 2010 7:15pm |
I used a flexible 60mm silicone hose that has a steel spiral in it to prevent it collapsing, heat loss was not a problem managed to have over 20degrees in the tent when only 1 or 2 outside |
13th Dec 2010 7:24pm |
Filling rear wing tanks is awkward, the problem is where to fit a filler without drilling the body. |
13th Dec 2010 7:26pm |
Excellent.
I looked under the front wing top earlier. I cant be arsed to move stuff, take it out and replace, though admittedly it would be great to put a spring catch on the blanking plate on the wingtop and have the tank underneath and fill it that way. I have an aux tank under the o/s rear wing anyway, so the other place is n/s rear. I'm going for an eberspacher not a webasto, and i m going to fit it on the wheel box top n/s so a tank under there would make the most sense. its just filling it that will be a so i m going to get someone to make one for me, probably in steel rather than alloy for the bracket strenth. May well have to fill using a pipe and funnel which isnt ideal. I guess I'll need a fill level indicator on the side of the tank |
13th Dec 2010 7:49pm |
definitely not enough space under the wing top. So I'm looking at having a 1.5 gallon tank fabricated to go under the sill, but having the filler pipe go up into the wing top so the filler would be accessed via the blanking plate on the n/s wing. Going to put a spring loaded hinge on the back of it and a locking catch and that should be a pretty cool solution.
14th Dec 2010 12:24pm |
Thought that the near side vent was for the heater air intake?
14th Dec 2010 1:02pm |
durr yes of course, it'd be offside. my mistake in my excitement at being able to lift the wing flap and fill a tank
14th Dec 2010 1:11pm |
