Home > Maintenance & Modifications > Steering guards, lifted and castor correction
Hufflepuff
Day 3 of fitting the Gywn Lewis kit and the end is in sight.
However, run into a spot of bother with the "First Four" steering guard and the front steering arms.
The car is lifted by two inches, with castor corrected arms which has rotated the whole axle round a few degrees. This in turn has moved the front steering arm a little bit further forward, so that when in the closest position (steering dead centred) the arm is about 1mm from the guard. This is well outside my tolerances, is this a common problem?
I can rectify the issue with an angle grinder and slice off an inch off the bottom of the guard, but that seems a pity as its a nice powder coated aluminium one.
A second and more important problem is the covers for the front shock mounts. They will no longer fit as the top of the shocks sits about two inched inside the engine bay. What do people do about this? Just let the dirt from the arch splash up into the engine bay, or does any make extended covers?
I would have had a go at making some myself except the inside aluminium skin of the arch has quite a unique profile.
Apologies for no pictures of these problems, I do not have a pc handy to upload them on.
Post #461001 6th Oct 2015 6:07pm
jst
personally i would adapt the steering guard
i make up my own plastic guards to cover aorund the top turret as best i can Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #461058 6th Oct 2015 8:20pm
Hufflepuff
OK thanks for the feedback James, out with the angle grinder in the morning.
For a matter of interest, did your modified turret covers start off as the original ones modified? I was thinking about cutting a hole in them for the turrets tops to go through.
Post #461120 6th Oct 2015 9:41pm
K9F
I too had to 'modify' my SVX steering guard when I replaced my bumper with a HD one with recovery eyes as the steering guard would no longer fit. Out with the angle grinder after carefully masking up the cut-line. Trip to the powder coaters to get it redone afterwards and you would never know.
Thumbs Up
Excuse the poor quality picture.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #461129 6th Oct 2015 10:10pm
jst
no, i made up sep ones. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #461253 7th Oct 2015 11:55am
