Home > In Car Electronics > Kenwood Cubby Active Sub Install |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2041 |
Will take some photos soon and forward on to you.
5th Oct 2015 4:25pm |
Do you have suitable radio fitted with the blue/white power wire and RCA lead connections on the back ?
Go on, fit a sub, you can do it, it's not that hard! Just a bit of thought and planning and you'll have it done. The wiring instructions are easy enough to follow. Plan your wiring route, mount the sub, and job done. |
20th Oct 2015 8:26pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
right after a couple of month of use my opinion,
is this a worth while mod? Answer yes, But I have however put the standard speakers and tweeters back in the front as the previous Kenwood front speaker upgrade was just too tinny , so if I could go back in time the Active Sub would be the first ICE upgrade I would do. Note of caution is that everything in the cubby now rattles in time to the music!!! I think mounting the Sub unit nearer the rear of the car and connecting to the rear speaker wires might be a better idea than the front speaker wires and back of the cubby. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Oct 2015 8:35pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
Found this thread out, went and brought 1 and fitted it today. What an upgrade!! Well worth it. Annoy paid £99 for it
12th Mar 2016 12:14pm |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 502 |
Got mine as a Christmas present. Fitted it today and it's absolutely fantastic! Finished off my audio setup perfectly. The controller is very handy since I just have an amp and not a head unit. The most difficult part by far was marking out and drilling the holes to mount it to the cubby. I didn't use any of the fixings it came with - just used 6 longer bolts and washers. I also put mine upside-down for more convenient wire routing and since I have a bulkhead you can't see it's upside-down anyway.
As for wiring it up, my amp has an RCA out for a sub so very easy. For £97 on Amazon it is definitely worth getting. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
26th Dec 2016 6:26pm |
jamescaudrey Member Since: 14 Jul 2018 Location: holbæk Posts: 3 |
What fixing did you use because I can't see the brackets from the kit
14th Jul 2018 4:34am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Drilled through the cubby and screwed straight on. Threw the brackets in the bin
14th Jul 2018 5:26am |
are you using the six bolts that hold the front on
14th Jul 2018 7:02am |
no, just used the machine threaded holes that the brackets are supposed to attached to. 4, 1 at each corner and then used longer screws to go through the cubby.
14th Jul 2018 7:05am |
Yep I did the same as above Matt.
14th Jul 2018 7:11am |
Thanks Guys
14th Jul 2018 7:46am |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 |
To run the kenwood sub do you need an amp or is this built into the unit?
Depending on the above answers, is the sub just wired into the standard speaker wires or does it have a dedicated sub speaker conection on the sterio? Last daft question sorry, has anyone fitted one of these on a metal cubby and did they have any issues???. Cheers in advance.... |
14th Oct 2018 10:23am |
